Oil leak (with pic)
fannyj
Tue Mar 06, 2007 8:16 am
Hi Guys,
The other day i noticed a few drops of oil in my garage, had a look around and think i might have found the cause.. Is this common ?
Can it be fixed easily ?
Fushion_Julz
Tue Mar 06, 2007 3:45 pm
dead easy fix...
there is a circlip which you need to prise out...be careful not to loose it!
be careful as it comes free...the valve behind is spring loaded and will pop out a little...
There is (or should be) a rubber 'O' ring around the neck of the valve...Replace this and put it all back together..
Took me around 15mins and that included 5 or so hunting for the correct size of 'O' ring!!
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
Templ8e30
Tue Mar 06, 2007 4:42 pm
BMW do a modified part for this common leak.
GASKET SET 11429059338, it's about £8
Cheers,
Iain T
2007 Mazda 6 2.0 estate
