Intermittent wipers
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Mon Mar 05, 2007 10:02 pm
Hi guys,
Seems the new iS has developed an intermittent fault with the wipers. Sometimes they just plain stop then a day later come back. Needless to say this is noticed when rain around. I think I've eliminated the stalk simply by long terms repeated clicking through all positions. Obviously not the fuse as they come back to life after some time so I'm guessing it's water getting to parts it shouldn't then when it drys out it comes back to life. Are there any common places to look for trouble? Where should I start to take apart first?
Cheers,
Ashley
Chris-W
Post Mon Mar 05, 2007 10:19 pm
Wiper motor itself - the contact disc is prone to dirt / corrosion. I think there is an article in the, ahem, articles section :)
SPADGE
Hi Ashley
Its common for the wipers to go Pete Tong on E30's
If your problem isn't with the relay or a dodgy wire this link may help
http://www.e30zone.net/modules.php?name ... wipers.htm
Ziggy
Post Mon Mar 05, 2007 10:23 pm
There's an article in the 'articles' section at the top of the page... it's your friend - get to know it :) Although that's more about faults with the intermittent wipers than intermittent faults with the wipers :mad:
Ziggy
Post Mon Mar 05, 2007 10:24 pm
:lol: too much beer = slow typing!
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Mon Mar 05, 2007 10:26 pm
cheeers guys - I got the hint - check tech articles :)
I've browsed them before but didn't remember seeing the wiper one.
However, if it were a motor problem I'd expect symptoms like a weak stroke (sounds very wrong:)) but these is either working 100% strong or 100% dead.
Chris-W
Post Mon Mar 05, 2007 10:28 pm
Nope - the way the disc fails means you get 'staccato' failures, or even just wipers stuck at the top of the normal stroke.
Find the article, you will understand!
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Mon Mar 05, 2007 10:39 pm
Article Heading:
Potential Cure For Stuttering Windscreen Wipers On Intermittent Setting
Written & Photographed by Peter Laing (PeteE30tourer)
And yes, I did read the whole thing.
My last e30 had the problems described above and my current problem is quite different. As I said either they work 100% like new, or they're 100% dead for a day or so - not a whisper of movement on the wipers, not check but I'd wager the cost of the back plate that the motor isn't being energised at all - not wanting to be ungrateful of the help I will check it out.
Unfortunately intermittent problems are the worst and it seems to need rain to show itself and I don't want to be out doing electrial diagnostics in the wet :(
SPADGE
Post Mon Mar 05, 2007 10:41 pm
Ashley
Read the 3rd line of my response earlier there is a potential clue in there winkeye
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Mon Mar 05, 2007 10:44 pm
Yeap sorry. Did notice the relay/dodgy wire comment. I'd already got it down in my mind that it was something like that but was posting for good places to start hunting.
ME wrote:Where should I start to take apart first?
relay should be easy to find of course :)
