SPARK PLUGS RECOMMENDATION -----------
--alpina--
OK, what spark plugs do you guys recommend for the 325i/ 2.7 conversion, i was told the Iridium (denso) are good??, also any place you know that supplies any spark plugs recommended...
Cheers!!
j
Cheers!!
j
NGK's BPR6ES job done!
makes a 325i super smooth
d6dph
Do a search for NGK, There are loads of threads for plugs.
**Edit - Si got there first, And he speaks the truth
--alpina--
These BPR6ES from what i read is that i understand its good for 325 up to 1986, ans i have a 2.7 built and its based on the 1988 head motronic 1.3 would these plugs do well with my engine?, id thought the bosch plugs being german and all, even thou its stamped "made in india " e.t.c. you`d thought is a perfect combination!!!
j.
j.
the 2.7 will like these plugs aswell. They have a slightly cooler running temp to the NGK's for the later 2.5 engines.
This is due to the higher combustion temps from a higher compression ratio so i believe. Most 2.7 conversions run decent compression so these are ideal.
The facelift 325's run very sweet on these so i'd use them on any M20! well i have and they all seem to run noticibly better
dazleeds
- old skool raver
ngk all the way
www.oldskoolfantasy.co.uk
d6dph
I have a late engine in my car, lower compression, that I used to run on the zgr5a plugs. Ant (and I think Simon) suggested using the bpr6es plugs and I noticed straight away it runs smoother on the bpr6es ones.
my old sport engine was mega mega smooth with these, those who can remember it!
--alpina--
Thanx for the replies so its the BPR6ES spark plugs ill need then? out of curiosity how much would a set of six will cost?? and any recommendations of what place i could get them??
j.
j.
GSF sell them no more than £2 a plug but i can't remember the exact price
--alpina--
Thanks all very much, i just checked the GFS website and they dont seem to state any plugs of such. mmmmm where else can i get em....
J.
J.
let us know what you think!
--alpina--
Well guys, i found this website that cross references with bosch :
http://www.spark-plugs.co.uk/pages/tech ... a-y6dc.htm
j,
j,
hoshy
- E30 Zone Wiki Guru
sorry guys I can't resist ... what about for the m42
RapidE30
You have to call GSF direct to get a price for plugs.
In their book it say NGK from a £1.
The 100% American is 99% idiot.
--alpina--
I emailed a company and this is what they said
"The early model can use BPR6ES, the later model (86 - 91) uses ZGR5A. Equivalent plugs of this type from any major manufacturer will be very similar - nothing to choose between them really.
6 x BPR6ES = £13.02+post+vat
6 x ZGR5A = £12.36+post+vat"
As my engine is a 2.7, the block is 1985, and the head is a 1988 casting, bit of a mix really, so which do i go for? what set of plugs? bit of confusion on this....
J.
J.
whats the compression ratio on your 2.7? i'd still say the plugs from yesterday!
Ant
- Retired Team Member
the weapon of choice ^ no 4 pronger iridium BS required, old tech for old tech, end ofBPR6ES
Email FTW
--alpina--
Thanks again simon and ant, BPR6ES it is, only recommendation by the experts as stated !!!
Cheers again
J.
Cheers again
J.
