My prop was split in half at the middle joint by my useless mechanic, who has subsequently given up on the job.
I know it has to go back a certain way but have no idea how to tell if it is the right way.
I couldnt find a guide spline or any features that look like guides to get it right...
what do I do??
325 prop problems.
munky30
- 100% Pure Council
oze30
have a close look. there should be 2 dots either yellow or white, but could be anything inbetween. these come out of the factory with these marks, so unless its been spray painted over, they should still be there. Then its a case of joining it up. Make sure the U joints are flat on both ends, 1 tooth out I have found isnt bad, but spot on would be best.
munky30
- 100% Pure Council
where are these dots... I couldnt see any..
munky30
- 100% Pure Council
ok I have found one of the dots... on the front half... the rear half is still attached to the diff so will have a look when I get the car up on ramps.
i take it the other dot will be on the outer sleeve like this one is?
liam012
as far as i remember the probs are joined and balanced from factory with (i think) the knuckles opposed ie the two swiveling joints at 90 degrees to each other.
you have a 50% chance of getting it right if you slip it together with the knuckels/swivel joints opposed and if wrong you will only have to rotate 180degrees.
i am a bit sketchy on this brianmoore i beleive might shed more light if he sees this as i heard himn]mention this before aswell.
if it hadn't been taken apart before and you needed to split it marking it with some tipex won't hurt
munky30
- 100% Pure Council
we didnt need to split it, my mechanic was being a spack and forgot to detach it from the gesarbox before he started yanking the engine out.
No chance to mark it as he didnt know it was splitting...
This is one of the reasons he is no longer my mechanic
That and the fact he has just given up and vanished, and I was paying him this time too!!!
But it has dots, well it has one so far, will try and find the other one tomorrow. ..
oze30
The rear one will be hopefully on the outer sleeve. Good hunting
