Removing the rear diff fixing bolts?
s1oww
Post Mon Mar 05, 2007 5:50 pm
Any tips at how to remove the top 2 19mm bolts holding the diff in place as they look a sod to get at?
Chris-W
Post Mon Mar 05, 2007 5:55 pm
They are a bit tricky to get at. Ideally, you should use a flexible head ratchet spanner. You might find a fixed head ring spanner with another spanner locked onto it useful for cracking it off to start with.
Ziggy
Post Mon Mar 05, 2007 5:56 pm
Ring spanner on nut, scaff pole on spanner. :thumb:
s1oww
Post Mon Mar 05, 2007 6:04 pm
Cheers, It will have to be a 2 spanner job as i dont have a flexi ratchet or scaff pole.
I'm off to do it in a min, i have a feeling im going to loose most of the skin on my hands, fun fun fun :)
DRIFTBOY
Post Mon Mar 05, 2007 6:36 pm
Ring spanner and a piece of exhaust pipe my favourite method.
If not, ring spanner and a club hammer! :D
E30Mark
Post Mon Mar 05, 2007 7:00 pm
Ring spanner, then lie on your back and push it with your foot!
PM for details
Templ8e30
Post Mon Mar 05, 2007 8:18 pm
I've got an extra long (400mm) 19mm combination spanner that comes in handy for cracking these bolts loose.
To get them all lined up when re-fitting I screw in the lower 2 bolts first then use a spare mirror glass to see when you've got the top 2 lined up. Fit the single bolt through the rear cover last as it lifts the whole axle assembly into place.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
clubfx2
Post Mon Mar 05, 2007 8:26 pm
I did this just yesterday... And its not a 1 hour job to switch diffs... Especially the first time...
Use lots of releaseing spray before attempting, mine was nice and gummed up with some corrosion.
I used my normal socket set, bit tricky to get in place, but you need a good secure fitting on the bolt heads. Lots of might behind it too, screwed bleeding tight...
Good luck!!!
Give us a shout if you get stuck?
Regards
Clyde
Go everywhere sideways...
s1oww
Post Tue Mar 06, 2007 2:50 am
All done, at 2.46am. It took forever to get everything lined up. Lovely weather too as we couldnt close the garage door. We snapped a few tools and my hands are killing, but she goes round now :)
Templ8e30
Post Tue Mar 06, 2007 11:26 am
Bitch of a job isn't it ?
My diff has been swapped so many times now everything comes off with ease, no rusty crusty nuts and bolts :D
It started life with a small case 4.1, then a medium case 3.64, then a 3.91, then a 3.73, now it's a 3.91 slipper :mad:
Cheers,
Iain T
