Nearside Electric Wingmirror
riche30
Post Sun Mar 04, 2007 11:09 pm
The nearside wingmirror on my 320i won't adjust properly using the toggleswitch on the drivers door. You can hear the motor whirring and the mirror glass tries to move but it's very weak, whereas the offside mirror adjusts perfectly.
Is there anything I can do to try to fix the problem before I go looking for a replacement wingmirror?
Cheers for any help :cool:
Post Sun Mar 04, 2007 11:38 pm
The motor mechanism can get damaged, but this usually results in teeth jumping on the rack and pinion gears, rather than weak motion.
Problem is probably in the door pillar plug and socket, but can be either the passenger or driver's door, since the signal goes through both.
There should be 12 volts at the black wire of the mirror motor all the time the ignition is on. (check with a 12V lamp, not a meter). Earthing the blue wire should make the motor move.
Don't touch the mirror switch while doing this!
