Hi, sorry if these are questions asked before but does anyone know where I can get stronger engine mounts for my 1987 325i sport? I went on my first track day yesterday and sheared both! I couldn't work out why I couldn't select 3rd and then the whole gear lever dropped 2 inches and I though " I may have a problem here"!
Also, the non assisted rack is a bit slow, apparently you can fit one from a 318 that is quicker?
Doug
Stronger engine mounts and quicker steering rack
ed325i
If you mean the rubber engine mounts you can get poly ones.
Gortour
If you fancy going over to PAS, the E36 and non-M3 E46 racks are 3 turns lock to lock, and the Z3 rack is quicker again.dougisaacs wrote:Also, the non assisted rack is a bit slow, apparently you can fit one from a 318 that is quicker?
Don't know about the 318 rack - I assume unassisted again, but expect 4 turns lock to lock on any E30 rack, bar the M3.
DaveD
- E30Zone Wiki Specialist
Turbo-Brown
- Boost Junkie
How on God's green Earth can a set of engine mounts improve acceleration?!
dougisaacs
I guess they could improve initial acceleration as if the mount compresses or flexes then to do that requires torque, that is then not getting to the driven wheels. However, once that initial compression has taken place then there would then be no effect, until you change gear and have to recompress them again. Or am I talking c**p?
ian332isport
The quickest E36 rack is approx 3.2 turns lock to lock, but most are 3.4. Standard E46 rack s are also 3.4. I believe the E46 sport rack is around 3 turns. Z3 is around 2.7 turns.gortour wrote:If you fancy going over to PAS, the E36 and non-M3 E46 racks are 3 turns lock to lock, and the Z3 rack is quicker again.
Ian.
Gortour
Thanks for the correction Ian.
brian325i
what does fitting a z3 rack include????into e30318is with m50(hit manifold..no i guess)
- Homo Hair
brian325i wrote:what does fitting a z3 rack include????into e30318is with m50(hit manifold..no i guess)
miniblob
Have a look at this post from the motorsport section for Z3 steering rack install - http://www.e30zone.co.uk/modules.php?na ... 98&start=0
If i wreck my engine mounts to quickly i might give those stupidly expensive ones a go!!
327 Touring with bass!!!
