Today before handing over my deposit I gave the car a fairly thorough inspection and all seems good, although there are a some points I need some help with.
- The guy I'm buying the car from has owned it for 8 years and has always put Mobil 1 fully synthetic oil in it. Isn't this oil a bit thin for the car? My main question for this is that there is a small leak right at the base of the timing cover that runs onto the sump.
- Was an LSD an option for the IS? I couldn't read the tag today as it was corroded.
- Does anyone make an aftermarket exhaust for the IS? The car currently has a scorpion half system on it that sounds a bit nasty and the DTM tailpipes stick out way too far (read chavvy!) The car is coming with the standard exhaust so I am going to fit that for now.
- What size are the front struts on an IS? Just to see what suspension kits are around. I've got apex springs from a 325 touring lying around - would these be ok?
This is my first IS after owning a 316 and two 325's.
Any help would be greatfuly appreciated.
[img]http://
