TOP TIP
exup
Boost Junkie
Post Sat Mar 03, 2007 10:23 am
My tip Aldi shops were selling ultransonic cleaners for £15.99, normally these are much more , + shops want 100 to 120 to do it
ideal for cleaning your 6 injectors etc or girlfriends rings watch cds etc etc
should be better than hand , i m going to put them into a solution of injector cleaner in it that should clean them plus u can stick a 9 v battery on them and open them up too
hope its of help :cool:
Templ8e30
Post Sat Mar 03, 2007 1:19 pm
I bought one from ebay last year, cost me £50 :x
Having said that is the aldi one big enough for all 6 at once ?. Also mine has a 20 minute timer, the cheaper ones only run for a minute or so which isn't long enough for injectors.
The best ultrasonic solution for injectors is the stuff from RS. Works wonders, the solution turns black in seconds.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
exup
Boost Junkie
Post Sat Mar 03, 2007 8:18 pm
Hi Ian
yet u can get 6 in it , but i went for3 at a time , only got a 3 m in timer but just keep reseting it , we use radio spares \t work what fluidm did u use ? , i use electric cleaner firat then injection cleaner
how the M/S GOING , DID U CHANGE FROM A STD 325 CAM IN THE END? ,
I M LOOKING AT M/S TOO , SO I CAN PLAY WITH LPG AND DRY NOS
Templ8e30
Post Sat Mar 03, 2007 8:29 pm
Exup, I use this stuff diluted with cold water
http://rswww.com/cgi-bin/bv/rswww/searc ... uknetscape
Recommended for carbon deposits etc.
Lifts the external shite off the injectors in seconds
I leave them in for 5 mins to clean the outside then change the fluid and power the injectors up for the next clean of 15 mins. Works a treat, restores a really good spray pattern
Cheers,
Iain T
