Rear Wheel bearing, help
J_Mac
i've got everything out and off apart from the outside of the wheel bearing itself, all the ball bearings came out when i hit it with a hammer, only thing left is the outer bit, i've tried everything i can think of and haven't got a "puller" tool .. any help at this point would be great as my cars in bits
ric325i
dude thats bad news.
i have just got in from changing my front wheel bearings! couldn't buy the the wheel bearing so had to buy the hub.
£120 each from bmw
£70 each from another place i thought waw cheap
£80 for both at euro car parts
all the haynes said fro the front was tab with a hammer but it sounds like you have tried that.
it has too come off! just unleash a the sledge hammer on it
£120 each from bmw
stuartgallafant
ric325i
i have just been looking at the slide hammer things and i dont have a clue how they work?
how much of a pain is it having to have the correct tool for the job
but i did buy a big breaker bar today
very useful
stuartgallafant
slide hammers are easy to use!!
you just attacht the plate on to the hub, then attach the slide shaft inside the plate, then using the slide throw, just hammer away until you pull the hub off. then undo the plate/hammer and then put the other little bit behind the bearing and use the same action as before
Andy335Touring
Have you got a Dremel with a small grinding bit ?
Care fully grind a grove through the race, it will ping/crack then it will tap off easy.
ric325i
that sounds better than attempting the self love with your car (slide hammer)Andy335Touring wrote:Have you got a Dremel with a small grinding bit ?
J_Mac
its just the outside or the bearing, the case so to speak, it's ceased in there like i don't know what, and it's harded steel so grinding would be ok if i could get in thee but a jigsaw blade stood no chance, i tried.
wish i'd of said earlyer, stuart i would have took you up on your offer, i'm quiet stuck
J_Mac
ok had enough, it's late, cold, knees and arse is wet. I tried a compression way with 10mm thread 2 nuts a socket and a metal plate, with the socket at the back with the thread through it (nut on the end) the plate on the front (with the other nut)and tightened the 2 nuts untill........ the thread snapped, long ways! mayjor torque and no movement. If a wake up in the mood i'm in now the grinder will come out and won't go away untill it's out
stuartgallafant
J_Mac
done it thanks stuart, and just to answer your question not that far at all, about 20 miles give or take (my girlfriend comes from caterham)
I ended up disconnecting all the drum brake off and taking the trailing arm off, put upside down, socket on the back and a big sledge hammer later and it's out, not bad for a wanna-be mechanic/novice
(pisst whats the stub axle)
stuartgallafant
what a small world, my bird lives in caterham too! on the hill!!
anyways, i didnt realise you were doing it on a drum brake car... urgh!!
the stub axle is basically the hub at the rear of the car. if you have rear discs, you have a driveshaft, that will go through the stub axle, then a massive nut
number 1 in this pic
well done for doing though mate
if you ever get stuck or want some help or anything, drop me a line mate
J_Mac
indeed it is
never thought it would turn into such a big job
thanks for the offer, no doubt you will hear from me again
(note to self, must get arse in gear and get up to the westerham meet)
stuartgallafant
