just finished messing about and husseling guys around with my M
THAT'S GOOD THAT THERE ARE SOME GOOD MECHANICS STILL AROUND
Had some oil leak from the front and the back of gear box,
so desided to get it fixed,
but input shaft case was damaged tube separated from the casing ,so oil
was comig out ,canged casing, seal ,
than gear selector seal , knucle, output shaft seal,
new clutch,
new center piece
new back box
all it neds now is new distributor casing seal wich i've ordered and
O ring
NOT BAD
bad casing ( tubeseparated from the case , )
now this is from other s14 fits bot needs to see how big is endflow ,
2 spacer rings one top one bottom
new seals at he back
and finaly
At least if i go MAD and deside to sell my BABY some gonna be a one happy man
