new trackrod ends and bottom arms!!!!!!
e30bmlover
Ac Schnitzer prophet
Post Fri Mar 02, 2007 6:25 am
hi all, i had the above mentioned items but on my car yesterday, and i must say what an improvement, the steering is tight, the car dosent feel like it wants to roll over when you go around a corner.... great!!!
now..... why is the steering tuggingwhen i turn the wheel sharp.... tugging meaning... the steering goes a little light then tugs and my steering wheel is not straight! i havent had the car laser tracked yet but surely this cant be the problem! i also have another steering rack to go on because the other has a tiny leak. any advice would be appreciated!
E30Mark
Post Fri Mar 02, 2007 7:46 am
You need your tracking re-set, but I can't believe you've changed your track rod ends and not swapped in the new rack first! You've got to do the job all over again now...
No point tracking the car if you're going to swap the rack some time soon...
PM for details
e30bmlover
Post Fri Mar 02, 2007 7:56 am
lol, the mug who done the track rod ends and bottom arms said he couldnt do the rack because it was too windy and the bonnet wouldnt stay up! more like he couldnt be bothered! if i get it tracked today, i could take it back and get it retracked for free!
E30Mark
Post Fri Mar 02, 2007 8:08 am
e30bmlover wrote:lol, the mug who done the track rod ends and bottom arms said he couldnt do the rack because it was too windy and the bonnet wouldnt stay up! more like he couldnt be bothered! if i get it tracked today, i could take it back and get it retracked for free!
That has got to be the worst excuse i've heard! could have parked the car the other way round, or used a broom handle :roll:
PM for details
Post Fri Mar 02, 2007 9:05 am
E30Mark wrote: I can't believe you've changed your track rod ends and not swapped in the new rack
At least they'll unscrew without problems.
Make sure the whole steering system is thoroughly flushed of old fluid. If you don't get charged for at least 2 litres of fluid, it hasn't been done properly.
jkarran
Post Fri Mar 02, 2007 10:04 am
Brianmoooore wrote:At least they'll unscrew without problems.
Do I infer this is a common problem? I had to use oxy aceylene to get mine off :roll:
jk
E30 320i Rally Turd - Usually broken
E24 635Csi - Rotting in peace for now
E34 540i - Daily driver
Blown R1 Striker - In progress
Post Fri Mar 02, 2007 6:54 pm
jkarran wrote:Do I infer this is a common problem?
Not if the last person to replace them knows what copper grease is!!
HenryM3
Post Fri Mar 02, 2007 10:33 pm
BMW do a seal repair kit fairly cheap for the steering rack. If your steering wheel is offset then some lazy git tracked it on one side only or just put the steering wheel back on one notch out.
Henry :?
Post Fri Mar 02, 2007 11:18 pm
Steering wheel is on correctly when it turns an equal number of turns in either direction from the straight ahead position before it hits the stops.
If the car doesn't run straight ahead when the rack is in the centre of its travel, something is set wrong, front or rear, or the car is bent.
Bob_S
Post Sat Mar 03, 2007 1:24 am
get that old rack off and get the new one on mate! then get it all tracked up, best way.
TBH new bottom arms are the best thing you can do with an e30 standard susp wise. and the lollypop bushes too
Bollocks to this 24v scrap!
e30bmlover
Post Sat Mar 03, 2007 6:15 am
hey bob hows the m3 mate???? she on the road yet?
i took the b20 to fast fit( i know, load of mugs) some @ucking useless tosser came to me( i was watching him) and said ''i cant free the blot to adjust it'' i thought this is strange, turns out that the track rod ends have not been done, rang the bloke up and he confirmed that he didnt do them. getting them done friday the 9th with the rack. i paid £60 for my bottom arms to be put on(inc new bushes) is this good?
next thing on the list is to fit the e46 (cab) top mounts i got(i can do that!!!) and rear axel bushes. new inner+outer arches, fit my front bumper i got from dobbie( still not on yet!)
and when its all done(bush wise) i will be driveing it round corners like im ravaglia!!!
