hi,
i also got a fuel smell from inside the car, but i traced it (i think) to the throttle body.
i'm not a machanic so i don't have a clue what i'm doing, anyone have any advice on what i should do, or simple possible repair?
1990 e30 316i - M40
cheers.
strong fuel smell
Check the fuel hoses, they eventually develop cracks and go porous with pinhole leaks.
andyborris
For what's worth (M50 engine in Tourer), I was getting a strong smell of petrol inside the car too. Could also smell it from around the bonnet, even with the engine off, but only after a run.
Was the fuel return pipe from the injectors, may be worth looking under the bonnet with engine running and also switched off, a torch can help too. Don't forget, there may high pressure fuel in the fuel lines, even with the engine switched off.
Just don't smoke while you do it!
Hyperion
Hi kuSt
i had a fuel smell problem aswell, i took it to a mechanic and asked him to look to see if the fuel lines were old and failing, he turns around and tells me they are fine, but my injector O rings were leaking fuel and make a mess. So ask someone to check on those too, if you look they will look wet and oily.
cheers
cheers
Templ8e30
Common problem with the M40 engine, the 2 short fuel hoses on the injector rail (under the inlet manifold) rot and piss petrol on top of the engine.
Proper fire hazard, sort it ASAP with quality fuel injection hose not the cack stuff sold down the discount motorist store that can't handle the pressure.
You'll need to remove the top half of the inlet manifold (new gaskets are a very good idea), the 2 pipes themselves are a swine to remove. The old pipes will be hard and brittle, best to slice them with a knife to get them off.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
kuSt
thank you all for your responses, i really appreciate it.
i've only had the car a couple of weeks (it's pretty shabby but i'm going to try to fix it up a bit). having a closer look at the throttle body i noticed a hose (from the right hand side as you're facing the throttle body from the passenger side f/wing) coming from it that has been blocked off (someone's stuck a bolt into it and wrapped it up!) i've taken a picture of it but i don't know how to insert it into this reply...
so this hose is from the injectors Iain? its quite a small one jammed in to the right of the big air intake hose...should it be leading somewhere? any one know why it could have been plugged up?
thanks again everyone for your help.
cheers.
cheers.
Templ8e30
Does this pipe come out of the bottom of the throttle body ?
If so it's supposed to be blocked off unless you have the black carbon canister fitted to catalyst equipped cars.
Have a look here http://www.realoem.com/bmw/showparts.do ... g=13&fg=15
The fuel pipes in question are numbers 16 and 17.
Cheers,
Iain T
Cheers,
Iain T
ad318i
i had it on mine..
i got some pipe from the dealers (genuine stuff of course) and i got a lil left over... more than enough than you need if you want it..
youll see if its the pipe...
turn over engine and look under inlet mainfold...you will see the fuel leaking..
1989 Alpine White 318i 4 Door - Got Scrapped When I Was Abroad
1993 Metallic Green 316i Touring - Im Selling it before i move back to Greece, http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0239342139
kuSt
Thanks for the offer ad318...i'll have to def make sure it's the hoses, if it is, i'll take you up on that, n1.
need to check it again in daylight 2moro...been outside in the dark with a torch sniffing my engine, the neighbours'll think i've lost it.
i think these pics have worked (clik for full size), this shows exactly where the hose connects, but yes Iain, it does go directly to the side of the throttle body...
i thought this may have been the problem, but i think the hoses you mean are further down underneath the air intake.
just noticed another hose without a clip on (it runs from underneath the air intake manifold into the head just behind the distributor) and it looks like it has something leaking out. have no idea what that is...i should probably stop looking, looks like hose hell!
