Headlight lighting problem.... anyone know?
RapidE30
Post Thu Mar 01, 2007 9:16 pm
Right.... since I bought my Tourer when you have sidelights on the drivers side dipped light is on but only about half power, the dipped lights now work ok as does main beam (now I've changed the bulbs).
Why does it do this? :?
The 100% American is 99% idiot.
Templ8e30
Post Thu Mar 01, 2007 9:19 pm
Bad ground connection ?
Check the grounding point next to the left hand headlamp on the inner wing inside the engine bay.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
RapidE30
Post Thu Mar 01, 2007 9:27 pm
Templ8e30 wrote:Bad ground connection ?
Cheers,
Iain T
I looked at this earlier and the 3 odd earth points look like they need cleaning up.
I'll try that tomorrow and see how that goes, cheers. :cool:
Post Thu Mar 01, 2007 9:38 pm
Iain T - You should know better than this!!
The real question is why isn't the passenger dipped beam on at half power as well.
This is the dim dip driving light function that looked like it was to become law at about the time this car was made.
It's a '88 or early '89 car, right?
If you look immediately behind the left hand headlamps, high up on the inner wing, you will find a clamp holding two large wire wound resistors in place. A wiring loom from these resistors ends in two round rubber plugs connected to matching sockets coming off the loom along the wing.
One of these resistors will have failed, or more likely, one of the wires rotted off.
You can either replace the offending resistor, or just disconnect both plugs and remove the resistors and loom.
The lights should then behave as later ones.
RapidE30
Post Thu Mar 01, 2007 9:43 pm
Brianmoooore wrote:Iain T - You should know better than this!!
Yep, a 1989 car. A guy at work mentioned these resistors but I thought he was taking the mickey..... apparently not then. :o:
Templ8e30
Post Thu Mar 01, 2007 10:22 pm
Never actually seen these resistors on an E30 :o:
Cheers,
Iain T
