IS MY RADIATOR FAN MEANT TO BE RUNNING AT ALL TIMES???
e30_widebody
hi, if just bought a e30 cab 325i and is i started the car this morning i realiesed the the radiatior fan was running even tho id just started the car and the engine was cold..... is this normall???
jcjdavis1
Hi. Yes if it has viscous fan. nice looking cab.lovely colour.
e30_widebody
thanx mate how do i know if its a viscous fan mate??
Chris-W
e30_widebody
ok so is it normall to be running all the time if its a viscous fan??
Chris-W
e30_widebody
thanx for that mate... i thought i had a fan problem lol... thanx again
It's only free wheeling around, and drawing very little power. When the coupling locks up the fan will make quite a loud roar when the engine is revved.
If this car is new to you, check that is doesn't overheat when you let it idle for a while with the heater off, as duff viscous couplings are relatively common, and 325 engines don't take kindly to being cooked!
e30_widebody
yeh i have noticed that if i leave it on idle with heathers off the car will slowely get warmer to just over the half way line.. this will happen after about 30 mins on idle but iv never left it on idle long enough to get it past there.. is that my couplings??
As long as it cuts in before it approaches the red section it's OK, but it's as well to find out before you get stuck in summer traffic!
It's not a serious problem as long as you watch the gauge. Heater full on is usualy enough to bring the gauge down again.
e30_widebody
thanx brianmooore.. is it a expensive problem to fix???and would i tell my mechanic i need as i dont work on my car myself??? lol...
jcjdavis1
Hi you can visit the Euro Car Parts web site to price items.
It's VERY expensive to fix IF you ignore it and cook the engine!!!e30_widebody wrote:thanx brianmooore.. is it a expensive problem to fix???
The couplings can be bought new for around £30, IIRC and are about half an hour to fit.
nr
</lurk>
Just did mine on my E24 635CSi - it helps a lot if you have the right spanner. GSF do one, part # 98739 for a few quid.
First post - please be gentle.
nr.
nr.
stuartgallafant
e30_widebody
thats correst mate.. had it fully resprayed in e46 m3 pheonix yellow
Barnz
- Guildford Geezer
Or ECP do one - part # 206110020 for a few quid toonr wrote:</lurk>
Sorry to nick this thread briefly but if the temp goes up just above the 2/3rds mark on idle then comes down when you rev to above 2k for a few seconds, is this the coupling too??? Seems like the coupling works so I'm suspecting a blocked rad? Again sorry for hijacking
E34 525tds - on the way to replace 325i
E30 / 34 spares
E30 / 34 spares
