316 needing engine change
kylepiggy
Post Thu Mar 01, 2007 2:31 pm
Hey guys new here so hello to every 1 i have just bought a 1989 E30 316i but it needs an engine so just wondering what engine will go straight in does the 1800 lump fit straight in or how much work needed to fit 6pot 2ltr lump. if any1 has an engine i need 1 as long as it has sensible milage. if any 1 can give me some advice would be a great help cheers guys
eko
Old timer
Post Thu Mar 01, 2007 2:34 pm
Welcome aboard Kyle :)
1.8 M40 will drop straight in there no problem.
2.0 M20 isnt worth the hassle but the 2.5 M20 is.
Sure Spadge on here was selling a good 1.6 pretty cheap,either PM him or put a wanted ad in the relevent section!
kylepiggy
Post Thu Mar 01, 2007 2:41 pm
Thanks for the quick reply so what mods would i need for a 2.5 lump ???
eko
Old timer
Post Thu Mar 01, 2007 2:45 pm
kylepiggy wrote:Thanks for the quick reply so what mods would i need for a 2.5 lump ???
Ideally you could do with a full car to salvage all the parts from if your going to go this route!
Engine/box/prop/diff/susp/brakes...............the list is endless.
Probably a good weekends works would get it up and running!
Swap for 1.6 or 1.8 though could easily be done in a day!
Best update your profile to say where in the country you are too,saves everyone having to ask you all the time :)
jbee
Post Thu Mar 01, 2007 2:53 pm
If you change from a 4 pot to a 6 pot would'nt the wiring loom have to be changed :?
eko
Old timer
Post Thu Mar 01, 2007 3:04 pm
jbee wrote:If you change from a 4 pot to a 6 pot would'nt the wiring loom have to be changed :?
Pretty sure the main car loom is the same except the 4 pot wont have the wiring for the check control panel.
Engine loom should just plug and play same as with the ECU :)
jmc330i
Post Thu Mar 01, 2007 3:30 pm
Yup, get a 2.5 with the loom attached and it will just plug and play. Only bit of wiring I did when fitting the 2.5 to my 318i was running the starter cable down from the battery to the starter.
ECU is on the engine loom, so the ECU plug just needs passing through the bulkhead.
James
'91 325i Sport
'93 318i touring 16v
jbee
Post Thu Mar 01, 2007 3:44 pm
Cool, i learn somthing new every day :D
