INSTALLATION ERROR - TIS PROGRAM
NigelA
On trying to install the ETK/TIS program the following error message is given on disc 1:-
'SETUP INITIALISATION ERROR
Setup is unable to locate script file E:\MN95\BMW\ETK\ENGL\SETUP.INS
Error 107'.
How can this be resolved please?
Thanks in advance for any help.
Error 107'.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
1989 E30 325iT Grey
1990 E30 325iT Blue
Using XP professionnel by any chance?
NigelA
No, Brian, it's XP Home V2002 with SP2.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
1989 E30 325iT Grey
1990 E30 325iT Blue
No good asking me about computer problems, but I can't re install my ETK on my computer since I replaced my deceased hard drive complete with XP prof. Could be a SP2 problem, I suppose.
I shall be watching this thread with interest.
NigelA
Thanks, Brian. We will wait and watch then.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
1989 E30 325iT Grey
1990 E30 325iT Blue
Morat
There shouldn't really be any compatibility problems between XP home and Pro. Pro just has extra networking options so you can use domains properly/fully.
The error message really does look like a missing file, are you sure you've got the full install there? On the other hand, the path suggests that the program was written for windows 95, in which case you're more than likely to end up with some problems under XP anyway.
Do you have an old 98/95 machine you can test it on?
NigelA
Thanks for the input, Morat.
No, don't have a 98/95 machine to test it on, but I have more than one set of disks and they all display the same sort of error information on installation - and, as you say, it is an older program so it is quite possible that it is incompatible in some way with more modern software such as Win XP.
Any other comments or suggestions please?
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
1989 E30 325iT Grey
1990 E30 325iT Blue
Don't want to hijack NigelA's thread, but in my case, the same ETK was installed on the same machine as it won't install on now, shortly after i bought the computer, complete with pre installed version of Windows XP home. This would have been pre SP2, which I remember installing at a later date.
Only changes have been a new hard drive and the installation of XP prof.
Chris-W
ian332isport
Brian,
I'm running the ETK/TIS with XP Pro and SP2, so you should really be okay.
Nigel,
What install file are you using ?
You need to install the sysadm program before you install the main TIS or ETK.
Ian.
Nigel,
Ian.
316eyes
If this one of the ones off ebay, it could be duff.
There are a few guys on there selling copies of copies which won't install correctly, I speak from experience.
Managed to get an IT guy to sort mine out, but I still have to set it to English in the default values everytime I use it.
Anyone got the so called up to date version (in colour?)?; mine is 2005.
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
Tried my discs again tonight.
The instructions are:
Insert TIS CD into drive > My computer > Click on drive labeled TIS > open folder named Win95 > open folder named Bmw > click the folder TIS > click the file named Setup.exe > follow online prompts.
All goes well until click the file named Setup.exe . Thinks about it for a while, then I get the white X in a red circle: D:\WIN95\BMW\TIS\SETUP.EXE is not a valid Win32 application
Minor point; there's no file named Setup.exe in the TIS folder, just Setup.
316eyes
Is this any help Brian?
Instructions from my files.............
Extract this zip file (the price list) to somewhere on the hard disk.
Assuming you have extracted into the root directory of C drive then to install :-
1) Run sysadm
2) Select the menu option EPC > Load prices
3) Enter the path of the disk1 directory (c:\bmw0204\disk1\) and continue
4) When prompted enter the path to disk2 (c:\bmw0204\disk2\)
Refer to my website http://www.bmwpages.co.uk for instructions on setting the
currency and tax rates.
You will need to enter the directory location to suit your version.
1) Run sysadm
m3ben05
Remember trying to do something like this when I had a working ETK, but this is just for adding prices isn't it?316eyes wrote:Is this any help Brian?
1) Run sysadm
I'm just trying to install the ETK.(and to do that you first have to install the TIS.)
handpaper
XP hides filename extensions by default, try right-clicking on the file and selecting (I think) Properties.Brianmoooore wrote:Minor point; there's no file named Setup.exe in the TIS folder, just Setup.
Beyond that I'm pretty clueless, haven't used Windows in over 3 years.
ian332isport
Brian,Brianmoooore wrote:I'm just trying to install the ETK.(and to do that you first have to install the TIS.)
That's not correct. You need to install the Sysadm application first, and then use this to install the ETK and TIS.
On every ETK CD that I've used before, the Sysadm setup file is in this directory:
D:\WIN95\BMW\ETK\SETUP.EXE
Ian.
Well, finally got mine up and working again!!
Gave up on the instructions and just had a good look through all the discs looking for executable files.
Found one hidden on the ETK disc that installed sysadm, which then allowed me to install the ETK itself!
Still can't get the TIS to install, or another disc labelled KDS (customer service desk - whatever that is), but I didn't have those installed on the old hard drive either.
