fuel pump+ check computer
BLACK325I
Post Wed Feb 28, 2007 10:29 pm
is a 318 fuel pump the same as 325i, ive just converted 318 to 325i but havent changed the fuel pump will this make any difference
also need help on fitting a check computer into a 318
Post Wed Feb 28, 2007 10:51 pm
Exactly the same pump in a slightly different frame.
BLACK325I
Post Wed Feb 28, 2007 10:55 pm
thanks m8, will i need any thing else to do,
also need help on fitting in a check computer as my car was 318 it didnt come with one
Post Wed Feb 28, 2007 11:36 pm
BLACK325I wrote:thanks m8, will i need any thing else to do,
Pump is fine. It's matched to the tank.
325 uses a different tank and pump frame, but the actual pump is identical.
No four cylinder car has the check panel, and it's a major operation to fit one. Different main body wiring loom and fusebox, from the front right corner to the back right corner, via the left hand side, with a few branches across the car in between.
Can be done, but it's not easy.
