can see a pulse in my electrics (lights)
liam012
If i look at my interior lights or dash lights i can see a pulse as if every second there is a slight power drop
very disconcerting
any tests i can do to isolate and fix this?
battery not going flat, no other electrical issues.
very disconcerting
J_Mac
do you have an amp running in your sound system, sounds like an alternator on its way out
Get the battery drop tested first, and if that's OK, it's the alternator.
wildeian
pm
cliffybabe
- Powered by Nelly
as already posted above, but if u r running a amp or ice setup i would consider a bigger battery or a power cap just to stiffent he power supply
liam012
must be slack on the alternator as i had it all off for the timing belt at the weekend
thanks
thanks
chief
i had a similar problem last autumn
it was because the heating fan was seized. it was causing a pulse in my electrics, every few seconds where my lights would dim. and if you listen very carefully you would here a very slight click.
do all your electrical switches, dials etc work properly. any that don't try to eliminate them from the power and see if it still pulses the lights
HTH
HTH
Don't you wish there were a knob on the TV to turn up the intelligence? There's one marked 'Brightness', but it doesn't work.
Put a voltmeter between the alternator body and the car body with the engine running. Should be zero volts.liam012 wrote: i had it all off for the timing belt at the weekend
thanks
liam012
cheers brian
whats a good charging voltage for the e30 system? 14 volts under load? lights /heater/radio on testing over the battery terminals with with the car running or between big wire pin of alternator and body of car?
AndrewL
Depending on the type of pulse it may be a blown diode pack in the alternator.
I had just this problem last year and the dealer supplied diode pack (about £35 if I remember correctly) and 10 minutes work fixed it.
Andrew
Andrew
liam012
with lights on radio on and heater on full
i get:
0.08 to 0.03 volts from alternator body to engine bay earth point,
14.80 volts across terminals
14.60 from alternator body to positive terminal.
still that pulse - if it makes any sense it seems to pulse with the engines say just under every second.
i get:
About 14 volts is right, but it's not a voltage problem we're looking for.liam012 wrote:cheers brian
An E30 alternator is a three phase AC generator, where the AC is converted by a diode pack to produce a heavily rippled DC, which is effectively smoothed by the low impedance of the battery.
If the internal impedance of the battery has risen, some of the ripple can get into the car's circuits and cause flicker, etc.
If one of the diodes has failed, only two of the phases get rectified, and there will be a big dip to zero volts every one third turn of the alternator shaft, which even a good battery won't be able to smooth out, again causing lights to flicker.
These are fineliam012 wrote:with lights on radio on and heater on full
i get:
liam012
mmm
i wonder what is cauing it then?
Brianmoooore wrote:Get the battery drop tested first, and if that's OK, it's the alternator.
liam012
Sorry i overlooked that in the post
i think we have a hydrometer (is that right?) somwhere
Get the battery tested with a drop tester by someone who hopes to sell you a new one. They usually do it for free.
johnna
- E30Zone Irregular
Brianmoooore wrote:
"Get the battery tested with a drop tester by someone who hopes to sell you a new one. They usually do it for free."
Is this not just a long handed way of buying a new battery? LOL!
Watch out for the sales pressure!
Be a man for once in your life and sh!t in that boot!- Wilfred.
liam012
is it true that getting a 75a/h or 80 a/h per hours batt can kill the alternator as it is not designed to charge that much?
whats stock for a 325i? 60a/h?
No. I often leave the radio on all day at work at fairly high volume, and always buy the largest battery that will fit the tray. Never killed an alternator yet.liam012 wrote:is it true that getting a 75a/h or 80 a/h per hours batt can kill the alternator as it is not designed to charge that much?
Standard 325 battery is 65A/hr. 325 diesel is 85.
