Temp guage M40
Brian28
Post Wed Feb 28, 2007 6:56 pm
Hi, my temp guage doesn't work (registers nothing). Its an engine I just stuck into the car. I've earthed the wire to the brown sender, no response from the guage, so swapped the clocks for a spare set, but its still the same. Have I got the wires crossed up somewhere as I bought the car semi dismantled, and the engine I put in had a hotch potch wiring loom. The wire I'm plugging into the brown sender has two wire connectors in the socket, the sender only has a single contact? The other thing is, are the guys at BM haing a laugh with the sender position! Is it possible to remove it without taking off the inlet manifold?
Brian
For sale - E30 320i racer project - sold.
Post Wed Feb 28, 2007 8:53 pm
The wire to the brown sensor should have a two pin connector plastic bit, but should only have one contact in it. Wire should be brown/purple.
Check you haven't got it swapped with the connector for the blue sensor (brown/red and brown/orange wires).
Take the air filter/AFM and convoluted hose off to help with access to the sensor.
If you earth the brown/purple wire, temp gauge should go to full hot.
