sunroof adjustment??
eltel
Post Wed Feb 28, 2007 3:59 pm
hi there...i have a 1988 325 2 door fitted with an electric sunroof..does anyone know if you can adjust the sunroof to sit tighter, as when i get over 95mph the wind noise starts to come in through the front of the sunroof.
the seals are all good and it's only lately started doing it.
i remember adjusting one of my vauxhalls to cure the same problem??
thanks
for any help
Only in the good lord we trust.. In everything else we check!!
1988 325i Tourer, Lowered, Deep Dish Alloys, Obc, Cruise Control, Heated Leather Sport Seats....
Chris-W
Post Wed Feb 28, 2007 4:47 pm
You can adjust how the panel sits, yes. Need to pop the panel lining off at the front edge (carefully), then slide it back into the roof space.
You'll then have access to 6 torx head screws (3 each side) which give you a degree of adjustment for the panel.
eltel
Post Fri Mar 02, 2007 1:15 pm
cheers mate..thought there would be something!!
