The accelerator peddle is quite stiff to push down, any tips on making it smoother?
How do i tell what ratio a diff is,how do i check it is a 3.91 and not a 3.64?
Is it an arse to replace the bonnet release cable?
Any good quickshift kits?
accelerator peddle is quite stiff?
Replace it with a nice new ones1oww wrote:The accelerator peddle is quite stiff to push down, any tips on making it smoother?
There should be a tag attached to one of the rear cover bolts. Clean it up and read it. or just count how many turns of the input shaft you need to turn the output shafts, say, ten turns.s1oww wrote:How do i tell what ratio a diff is,how do i check it is a 3.91 and not a 3.64?
Easy enough. Take of the LH headlamp grill to remove catch complete with cable at the front end. Hardest part is threading the new cable through the grommet by the fusebox.s1oww wrote:Is it an arse to replace the bonnet release cable?
There's a few options from Z3s and the like.s1oww wrote:Any good quickshift kits?
I read somewhere that earlier E30s had stronger accelerator pedal return springs; sometime in the mid to late eighties, BMW revised them to have a lighter pedal. My '87 320iSE certainly seems to have a far stiffer pedal than the '88 325iSE I just sold. Good for economy though
