lowering a 320i
rebelcruiser
Post Mon Feb 26, 2007 9:45 pm
ive been offered a 60mm lowering kit for my 1991 4 door 320i but
ive seen somewhere there is two diffrent strut sizes like 45 or 51
is this right if so which size would be for mine :?
any help would be great.
Templ8e30
Post Mon Feb 26, 2007 9:48 pm
Your 320i will almost definately have the 45mm struts.
I'd avoid a 60mm drop unless you fancy clattering your sump on speed bumps and enjoy wearing out the inside edge of your rear tyres.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
rebelcruiser
Post Mon Feb 26, 2007 10:01 pm
just as well i asked because the one i got offered is the wrong size thanks for the info.
rebelcruiser
Post Tue Feb 27, 2007 10:18 pm
the kit ive been offered is shocks,springs but the fronts are the complete strut unit so
everything gets bolted on not just the shocks etc so doing this ive been told i can fit the
51mm kit because your changing the whole unit i need to find out asap so any help
would be great thanks. 8)
Post Tue Feb 27, 2007 11:33 pm
rebelcruiser wrote:the kit ive been offered is shocks,springs but the fronts are the complete strut unit so
I think you're asking if the complete small diameter struts can be replaced by the larger ones.
If so, the answer is yes.
rebelcruiser
Post Wed Feb 28, 2007 8:07 am
yes thats what i was trying to say :mad: thanks for the info.
