535i engine rebuild
Rik178m
Post Tue Feb 27, 2007 8:25 pm
Ok so I can get hold of a 3.5 lt e34 engine for pennies but its done 215k!!! I know its been well looked after but is it worth reconditioning it or rebuilding? Could I do it myself?? Cheers Rich
e30Alex
Post Tue Feb 27, 2007 8:43 pm
Yeh you could do it yourself, just need a little patience, however, as iam in a simular boat to you, i would put the engine in and use it untill it starts losing compression etc. But only if its okay at the moment.
These m30 engines can cover huge milages as they are understressed in standard form, however they do need regular oil changes/regular maintenance etc. Good luck!Alex
Im a two car man. Shame my bike gets used more.Damn the MOT!
Rik178m
Post Tue Feb 27, 2007 8:51 pm
Nice 1 sounds like a plan!! :D
gareth
Post Tue Feb 27, 2007 9:23 pm
if the coolant looks clear and the inside of the rocker cover isn't all foll of black goo then throw on a new water pump (they always seem to go, are a pain to get to in a E30 and cost about £25) and away you go :D
DRIFTBOY
Post Tue Feb 27, 2007 9:24 pm
The bottom end on M30s generally go on and on.
My 186,000 mile crank was way within tolerance and just had journals polished. The bearings looked fine but were, of course replaced.
Oil pump (expensive) was stripped and measured and was fine.
The top ends need a rebuild more often (but still do mega miles if cared for) as camshafts and rockers can wear. Oil spray bar can block (due to lack of maintainance) or even come loose - there was also a modification for it's bolts.
Heads can crack or warp so worth checking for that. If the head gets skimmed a thicker head gasket is available.
Water pumps are known to fail so worth putting a new one on.
Spigot bearing in the crank if the engine came from an automatic!
I'm still trying to get rid of an annoying rattle in mine! :?
Martin.
gareth
Post Tue Feb 27, 2007 9:34 pm
did the new tensioner etc not sort it martin? :?
DRIFTBOY
Post Tue Feb 27, 2007 9:41 pm
No! :(
I've just updated my main thread! :(
gareth
Post Tue Feb 27, 2007 10:07 pm
:cry:
