E36 323 tourer advice
d6dph
Post Tue Feb 27, 2007 3:59 pm
My manager is looking to buy an E36 tourer (can't convince him to get an E30) and has seen quite a nice 323 tourer.
Anything I should tell him to look out for. It's '97 in blue with 162k on the clock.
Here's the Ebay link:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... otohosting
stuartgallafant
Post Tue Feb 27, 2007 6:52 pm
have a look at where the rear subframe mounts on. the floors rot and fall out!!
d6dph
Post Tue Feb 27, 2007 7:45 pm
Cheers Stuart, I'm also going to look for any signs of a towbar being fitted, the seller recently sold a small boat so I'm concerned it has been used as a tow vehicle.
stuartgallafant
Post Tue Feb 27, 2007 8:12 pm
yeah, watch out for that! you'll have a chassis like a toaster rack!!!
d6dph
Post Tue Feb 27, 2007 8:18 pm
Correction.... HE will :snigger: I'm still staying firmly behind the E30 steering wheel.
stuartgallafant
Post Tue Feb 27, 2007 8:33 pm
good lad!!!
ShineOn
Post Wed Feb 28, 2007 7:36 am
Watch out for knackered bottom ball joints at the front, wrecked rear trailing arm bushes - both of which will give knocks and horrible loose wobbly handling. I don't think thats an engine that Nikasil was a problem for, but I am sure someone will know.
Post Wed Feb 28, 2007 9:14 am
it was but if its ok now its fine
Andyboy
Alpina Colada
Post Wed Feb 28, 2007 4:01 pm
The floor doesn't rot, but a really badly abused car MIGHT develop a crack in the boot floor where the diff bolts in which is easily welded up once the diff has been dropped down. I've never seen an E36 with underbody rot - all of mine are perfect and the oldest is a 1991.
That car would have had a Nikasil engine too, but if it runs okay at 162k it's not going to be a problem. £1900 was a bit dear though - I'd have said around £1400 for that.
d6dph
Post Wed Feb 28, 2007 9:10 pm
Well he bought it yesterday :lol:
Knocked the guy £300 i think, And is a very happy camper. I had a quick browse over it today and it looks nice. Will swipe the keys for an hour tomorrow to "run some errands" :D
He said it pulls really well, and is smooth and comfortable. Be interesting to see what it's like compared to my old turd?
tristan325
Post Thu Mar 01, 2007 1:32 pm
stuartgallafant wrote:have a look at where the rear subframe mounts on. the floors rot and fall out!!
Funny, That's why I got rid of mine! Hehe.... But it doesn't actually rot so much as rip! The floor is a known weak spot around that area. Easy fix, but from the quotes I got VERY expensive to repair and reinforce.
stuartgallafant
Post Thu Mar 01, 2007 9:59 pm
you say its an easy fix, but its not really. its a whole new rear floor pan, which my dealership quoted 3 E36 owners, in the space of 2 weeks, £3500 to repair... not worth on a car like that, unless its a low-mileage M3, in which case, it probably wouldnt suffer from this anyhow
andyboy, i can asure you mate, this is an extensively known problem with E36's. not sure why/what causes it, but i have had loads in at the dealership with this problem. Even a Z3 M-Coupe!! :eek: a call to the insuance company and £4000 and he was ok, but it does happen pal
Andyboy
Alpina Colada
Post Sat Mar 03, 2007 8:00 pm
With all due respect a BMW main dealer is not the font of knowledge on anything older than an E46. I remember you assuring me that E36 instrument clusters need recoding..................!
Yes it does happen OCCASIONALLY and the cure is to drop the diff 5-6 inches and weld the cracks before reinforcing the transverse boot floor rail - 'new boot floor' is a typical BMW Main Dealer knee-jerk bullshit answer - just like all the 'failed' Nikasil engines that in fact had just flooded. Witness a silver 323i that 'needed a new engine' which, when looked into properly needed the engine spinning over with the fuel pump fuse out for 10 seconds until it fired up - at which point the fuse was stuck back in and it was perfect.
Been there. Seen it. Done it. Wiped my arse with the t-shirt.
BTW my 1991 320i - fitted with a BMW towbar when new - has no cracks or rust in the boot floor................. 8)
