M20 opinions/facts...
Scrotty
Post Tue Feb 27, 2007 1:40 pm
okay another question has arisen within the pack :P
a late M20B25 lump....bigger valve jobbie.....how well does the head flow....for a 12v like?in comparison to say M50B25
tanks :)
Ant
Retired Team Member
Retired Team Member
Post Tue Feb 27, 2007 1:49 pm
you cant compare the 2V and 4V heads for flow, even with a 2mm increase on both valves the M20 will be down on flow compared to the M50, two small valves have a much larger effective area.
Thats not to say the M20 has nothing to offer us still, It will always have more soul than the M50/52 engine , and with effective mods as per Scott Players car, can still be a force to be reckoned with
Turbo-Brown
Boost Junkie
Post Tue Feb 27, 2007 1:54 pm
Would be interesting to see some flow figures for the standard castings and cams. Wasn't aware that the later M20B25 heads had bigger valves than the early types :o:
As for opinions, I did think about going the M52 route for my next project, but that kind of removes part of the challenge for me, I'm much more interested in seeing what sort of power I can extract from the venerable old M20 :)
The M20's wonderful to work on internally too (not that I've had anything to do with the M5x engines)
Ant
Retired Team Member
Retired Team Member
Post Tue Feb 27, 2007 1:58 pm
they are the same Alex 885 casting and valve sizes was unchanged throughout production.
inlet 42mm, ex 36mm cam for the early pre 87 cars is spikier though..
Turbo-Brown
Boost Junkie
Post Tue Feb 27, 2007 2:03 pm
Interesting, the earlier cam's got more lift or something? :)
I'm planning on keeping the head from Brown when I build the 2.8 as I rebuilt it less than 4000miles ago. That said, I've spoken to a CatCams dealer about a special cam for my uber wide power-band :)
handpaper
Post Tue Feb 27, 2007 3:11 pm
I'd like to make my m20b20 more interesting; it's already got a 325 TB, single box stainless exhaust (which is probably costing me power :() and ebay chip (DigiTechnik, they're still trading but don't do e30s anymore).
I'm looking to fit a Catcams 283/283 and either remap the Motronic ECU or go for a MSnS setup.
Is a remap feasible with that cam, and what speed is the standard top/bottom end safe to?
Yes, I know I should start with an m20b25, what can I say, I'm perverse (and don't have an engine crane)!
Scrotty
Post Tue Feb 27, 2007 3:41 pm
the older skool bm lovers use (cant remember exactly) a mix of e34/e30 M20B25/M20B20 parts to make a 2.3
some say its better than the 2.7 conversion as it revs better (dont ask me i only read there site before all the 2.7 owners send my a virus or somthing)
e21Jason
Post Tue Feb 27, 2007 3:44 pm
Hi
May good friend who last engine was the AMV8 (he was one of the designers) has been playing with m20 heads on his £250k Serdi flow bench, as he is building a monster N/A m20 but when you have the engine R&D machine shop to knock up the odd bit who wouldn't. I should get the figures form him next month and post a few tables.
The good news is the 885 flows very well for a 2 valve just down from the Porsche 2-valve. It is not just the flow rate at valve lift it also the tumble & swirl that promote good combustion are also good.
The limiting factor is the valve size, bigger inlet valves & throats are need for more power. Not much you can do about cam bearing thought as the friction losses very high compared to a modern 4-valve.
Jason
