Can the rear springs be removed by simply unbolting the rear dampers?
Did the tourings come with longer/stiffer springs than the saloons?
jk
Rear springs
jkarran
E30 320i Rally Turd - Usually broken
E24 635Csi - Rotting in peace for now
E34 540i - Daily driver
Blown R1 Striker - In progress
handpaper
I undo and support the inner end of the driveshaft, too, to avoid stressing the CV joints, but others may tell you not to bother. Same springs as the 325's AFAIK....
E30Mark
The tourers had stiffer springs yes.
I would just disconnect the shock, and then change the springs over, no need to remove the wishbone or driveshafts IMHO.
PM for details
PM for details
jkarran
Cool, thanks guys!
Just to be different I'm looking to add ride height (~35mm) rather than lower or stiffen it... ok ok, I'm not mad, it's a bargain basement rally car.
Just trying to decide, longer/stronger springs (£) or spacers (free
). Opinions welcome.
jk
jk
