Need help on tuning!!!
cypriot_boy_2k7
Post Sun Feb 25, 2007 2:57 pm
does anyone no where i can get any applications for my laptop, to tune my e30 1.6i and a data cable? :?
or any alternatives to tune the engine
thanks guys
Ant
Retired Team Member
Retired Team Member
Post Sun Feb 25, 2007 3:40 pm
you need an emulator unit, data cable, Win OLS software( or similar) and a lot of time
you'll need to find the offset values to break the maps out too dude.
Hardware cost, c£6.5K with a complete OLS .dll setup
If you want to "have a play" may I suggest a standalone ECU setup, much cheaper way of doing things, and will be a lot simpler than reversing the base maps into understandable values manually
HTH
cypriot_boy_2k7
Post Sun Feb 25, 2007 5:44 pm
woooow looks like i wont be doing that, what do you recomend i do to make the engine run sweeter, not as juicy, do you think its a good idea to remap the whole system?
Ant
Retired Team Member
Retired Team Member
Post Mon Feb 26, 2007 12:39 pm
it will never be a fireball, but if its juicy give the car a thorough service and see if you get the desired result.
Only when the engine is running in top condition can you asses it further for tweaking, anything else is a waste of time and £Â£ dude.
you can chip the ECU to gain some performance and economy, but again get it 100% as stock before changing anything
