M40 Versus M42, want to replace the engine
markus_74
Post Sun Feb 25, 2007 12:52 pm
Dear, Friends
I have E30 318i and recently I have also rebuilt it.
There is a junkyard here that offer me M42 engine complete with the ECU also cost about U.K Pound 350
My question:
Is it wise to change the M40 with M42? What is the advantage of M42?
Markus P Nugroho
Pal318is
Post Sun Feb 25, 2007 1:04 pm
I would definately change it Markus....For a start your getting 16valves instead of 8valves, it's also a very revvy engine, compared to most other bmw engines, let alone the m40 lump. You don't need to modify the m42 that much either to get more horsepower from it...Just simple mods.
You don't say where your based?? £350 for the engine and i'm assuming the gearbox too, is ok...How many miles has the m42 engine done?? Has it got history to back up the mileage.
For £350 i'd want a reasonably low mileage engine/gearbox.
HTH
Pal
Pal
Image[img]http://Image
E30Mark
Post Sun Feb 25, 2007 1:06 pm
You'll also need the gearbox / prop / diff / exhaust / coil pack & moutings from the 318iS...
PM for details
markus_74
Post Sun Feb 25, 2007 1:45 pm
Hi pal
I live in Kudus city in Indonesia, the engine may be from Singapore/Hongkong and no memory about the mileage, 350 is for the engine including the cost for labor. No gearbox because the seller said that I can use my Old Getrag 240, as the short block is same with M40, I don't know about it.
I the web I read that weakness of M42 is head gasket, is it true?
I prefer the high torque instead of high rev cause of the traffic here need it, does the M42 has the advantage of M40 like good gas response and high torque?
Markus
markus_74
Post Sun Feb 25, 2007 1:53 pm
Dear, Mark
I have try view the item you want to sale at the ebay, but there is no item at this moment.
What parts do you want to sell?
Markus
Andyboy
Alpina Colada
Post Sun Feb 25, 2007 1:54 pm
E30Mark wrote:You'll also need the gearbox / prop / diff / exhaust / coil pack & moutings from the 318iS...
You can use the flywheel/clutch/gearbox/prop and diff from the 318i - they will do the job fine. You'll need the engine with loom and coils and ECU plus the radiator. The 318i Rad might be okay but the iS has the bigger one from the E34 520i/525i 24v.
**BANNED**
Post Sun Feb 25, 2007 2:20 pm
Been thinking about this for a while.I fancy an ex E46 318i motor for our 316i Touring.Will I still need the doner ECU/gearbox etc?Could I get running on the ECU from the 316i without coil packs?What about exhaust?
markus_74
Post Sun Feb 25, 2007 2:26 pm
Dear, Pal
How about the torque? does M42 has high torque as M40 has in low rev?
Markus
Pal318is wrote:I would definately change it Markus....For a start your getting 16valves instead of 8valves, it's also a very revvy engine, compared to most other bmw engines, let alone the m40 lump. You don't need to modify the m42 that much either to get more horsepower from it...Just simple mods.
HTH
Pal
Post Sun Feb 25, 2007 3:27 pm
daimlerman wrote:Been thinking about this for a while.I fancy an ex E46 318i motor for our 316i Touring.Will I still need the doner ECU/gearbox etc?Could I get running on the ECU from the 316i without coil packs?What about exhaust?
Many, many problems on this one. Less work to put in a M50 and do a proper job.
Andyboy
Alpina Colada
Post Sun Feb 25, 2007 10:53 pm
If want an M43, get a non EWS E34 1.8 from a 518i, aA much better engine than the M40 (not difficult).
Pal318is
Post Mon Feb 26, 2007 12:09 am
markus_74 wrote:Dear, Pal
Markus
HTH
Pal
In the low rev range the m42 can be slow at times, but once you get to 4k rpm it really kicks and pulls very well. Not very torquey loaded up tho'
:roll:
Pal
Pal
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Mon Feb 26, 2007 2:10 pm
But keep it in the power and whooooohoooo ;-)
markus_74
Post Mon Feb 26, 2007 2:15 pm
Does put M50 less work? as I know it is bigger engine and has different short block.
I'm searching many option, I want to get is more torque and power and 6 cyl engine is better for me, but people here said it is difficult to fit it.
M50B25 is enough I think
markus_74
Post Mon Feb 26, 2007 2:16 pm
Have any advice for me? How much cost for M50B25 engine complete with all wiring, ecu and all to complete it?
Gibbo
Post Tue Feb 27, 2007 12:18 pm
So it sounds like the M42 and M43 are the easiest engine swaps for a M40. I've heard the M42 is a very rev happy engine but a bit scarse. What about the M43 anyone? Performance figures? (What is non EWS M43?) Cheaper than a M42 perhaps? I presume you need the same combination of engine, loom, ECU and radiator. So are they as easy as each other?
markus_74
Post Tue Feb 27, 2007 3:21 pm
Dear, Gibbo
Yes, I think M42 is the easies engine swaps for M40. Also if M42 rev happy, the torque will only come out in high rev.
I don't know the different between M42 and M43
