Following a couple of discussions I've read on here, I bought a set of BPR6ES's to replace the rather knackered ZGR5A's in my '89 325.
Normally you unscrew the little cap on the end to fit the lead on, but with the set I've got the end part is one piece so I wouldn't be able to fit the leads!
Whats the deal here then, are there different variants of the BPR6ES plug, and if so which ones do I actually need?
Plugs - BPR6ES vs ZGR5A
You sure the ends don't come off? IIRC, I had a set that looked like they were one piece, but it was just that the threaded hole in the caps didn't come all the way through, and they were screwed on tight.
Jackle
Yep, I managed to completely destroy one by trying too hard to unscrew the end - the shaft through the centre sheared and came out!
I've just had another look at the box and it's actually marked BPR6ES-11. Does the "-11" make the difference?
i've bought 2-3 sets of the BPR6ES plugs's and never had this problem the end bit just unscrews!
d6dph
Same here.Simon13 wrote:i've bought 2-3 sets of the BPR6ES plugs's and never had this problem the end bit just unscrews!
The -11 on the end of the part number refers to the gap. (1.1mm in this case)
Here's ngk's chart to break down the plug part no.
http://www.ngksparkplugs.com/techinfo/s ... berkey.pdf
IIRC from the LPG forums, NGK has a very helpful technical department on the end of a phone line. Give them a call.
