That ****in front brake disc bolt...
Ziggy
Post Sat Feb 24, 2007 8:46 pm
You know the one - the li'l allen bolt that holds the front disc on. Well one of the b***ers rounded off so I had to drill it... The question is what's it purpose in life? Just to locate the disc 'til you fit the wheel (& the disc is then held on by the wheel bolts), or does it actually have a structural purpose? Safe to drive without until I get a new hub, or not?
Ta :thumb:
dazleeds
old skool raver
old skool raver
Post Sat Feb 24, 2007 8:48 pm
iv had many without them in and never had a problem fella
also had to drill a few out :roll:
www.oldskoolfantasy.co.uk
Chris-W
Post Sat Feb 24, 2007 8:52 pm
Not structural at all.
Ziggy
Post Sat Feb 24, 2007 8:59 pm
Didn't think so (I am engineer afterall! :lol:), but I thought checking'd be better than my nice new zimmerman discs getting f**ed (/falling off!) because I'd missed something...
Wasted blimmin ages on it though, so that means I only got 3 wheels done this afternoon, & still have one & the fluid change to do tomorrow (ta for the tool lendage Mark!). :x
Cheers fellas :cool:
Andyboy
Alpina Colada
Post Sat Feb 24, 2007 9:50 pm
No problem at all . Don't need to drill anything - if you're changing the discs that is.
When fitting new front discs and the bolt won't move, just remove the caliper and smack the back of the disc good and hard with a big hammer. The disc will come off leaving the screw behind and a bit of disc. This can be removed with Mole grips and refitted.
Nay Botha!
Ziggy
Post Sat Feb 24, 2007 10:11 pm
Nice one! If it happens on t'other side in the morning, Mr Lump Hammer will be coming out! :twisted:
Post Sat Feb 24, 2007 10:29 pm
Plenty of copper grease when you put it back, and don't torque it up like the crank nose bolt! Will unscrew nice and easily next time, just like they did on one of mine this afternoon when I did a disc/pad change.
The next job I did involved removing the front bumper, and exactly the same applies to that as well!
Ziggy
Post Sun Feb 25, 2007 12:32 am
Yeah - problem was that I wasn't the last person to do it up; it was seized and half rounded off to start with; bit of a lost cause. :roll:
320Touring
Post Sun Feb 25, 2007 12:43 am
£0.64 from the stealer each too!
brian- Copperslip= the grease of the gods :cool:
