Drilling bumper bolts out!
andyborris
Post Thu Feb 22, 2007 10:32 am
As forewarned, the Torex bolts in the rear bumper of my Tourer are not shifting, I've killed one bit and it was a good quality one too! :(
Anyway, if I drill out the bolt heads, will I be able to remove what's left of the bolt from the bumper bracket, so I can refit the bumper?
Any tips? And are these fancy titanium drills any good?
If I can't this bumper off to fit this tow bar, I'll have to buy a Volvo with one already fitted!
Andy
SPADGE
Post Thu Feb 22, 2007 10:36 am
Even if you drill off the heads of the bolts it still won't come off as the threaded part of the bolt will still hold it on.
Have you tried removing the brackets from the bumper? I think they are nut/bolted on but not sure about access to them with the bumper fitted.
Post Thu Feb 22, 2007 10:49 am
Brackets can be a pain if the bolts are rusty, I have cut big sections in bumpers before to get at the bolts with a blowtorch/grinder.
Dont bother with Halfrauds T55 sockets, they just havnt got the guts. Mine lasted about 3 seconds.
I replaced mine with the Hexagon/Allen headed bolts.
SPADGE
Post Thu Feb 22, 2007 10:52 am
Here are some pics of a touring back bumper i have laying around that may help.
Usually you would remove the 2 big bolts (one either end) that pass through the metal plate shown which then attaches to the bumper.
If that big bolt is knackered and un-removable then you may be able to undo the 4 nuts/bolts attaching the plate itself to the bumper or at worst drill the heads off them and then the bumper will definatly come off.
Obviously you will still need to remove the big bolt and bracket from the car but it will be easier with the bumper out of the way.
andyborris
Post Thu Feb 22, 2007 1:11 pm
Thanks Spadge, but I think doing it this way is a non starter. Access is really tight, barely a fingers width and even if I can get a spanner on to the bolts, I doubt I'll be able to turn it!
But thinking about it, I don't actually need the bumper to come off, just need to move slightly backwards to give access, to fit the tow bar bolts.
Any suggestions?
http://cgi.ebay.co.uk/1994-VOLVO-850-T5 ... dZViewItem is looking very attractive right now :D
SPADGE
Post Thu Feb 22, 2007 1:48 pm
The only suggestion i can make really is to chop a bit out of the bottom of the bumper a bit like BMW did when fitting the factory option towbar :D
Post Thu Feb 22, 2007 11:38 pm
Remove the whole bumper mounts from the car! Easy on the back bumper.
Three 13mm nuts under the car, one inside.
You won't get the nuts and bolts shown in Spadge's pics off with the bumper in place.
Once the bumpers off, you can deal with the big torx bolts, removing the mounting plates if necessary to get some heat on it.
andyborris
Post Sat Feb 24, 2007 12:16 pm
Brian, I was told that the bumper mount bolts on a Touring aren't accessible?
Spadge do the Torx bolts go though both holes on the brackets in the pics?, just wondering if I can cut the bracket in such a way to remove the bumper and deal with the remains after? Have you got a pic of the part those Torx brackets are mounted on please?
Andy
gazza
Post Sat Feb 24, 2007 12:20 pm
dont know if this may help people with this problem later on but the last 2 cars i have broken up had allen bolts and not torx so if its not viewed before removing you could bugger it up using a torx in the allen key hole without realising
andyborris
Post Sat Feb 24, 2007 12:26 pm
No, mines Torx, worse luck!
Also wondering how easy it is to get all the plastic outers of the actual metal bumper bar, that might give me room to work.
Of course, that's assuming you can get the plastic off without removing the bumper!
Andy
Post Sat Feb 24, 2007 1:36 pm
Brianmoooore wrote:Remove the whole bumper mounts from the car! Easy on the back bumper.
