as title says wonder if someone could tell me how to remove
the ignition barrel lock.
thanks in advance
changing ign barrel
burnout
monkey
if the key still turns its easy . there is a hole beside where the key goes push a nail or pin in there will release a clip in the housing and the lock will come out the key needs to be in the first or second position for the pin to line up if you have the new lock you will see wot i mean . if the key dont turn you will have to smash it out bit by bit . good luck
burnout
monkey
bugger . i had to hammer mine not to bad just try not to damage alloy housing .
burnout
eko
- Old timer
Assuming you havent damaged the housing?burnout wrote:got the old one out without shredding too much blood
is there a nack to put the new lock in?
Just turn the key in the barrel to position 1 and slot it in,job done
gazza
zone article on the articles section here is the link to make it easier
http://www.e30zone.net/modules.php?name ... hnlock.htm
design cab and now 325 touring-
burnout
