325 touring, Pi springs not enough!
toughguych
Hello all,
Recently fitted Pi springs to my 325i Touring 1989.
Thought they may have been enough to solid the car up but it still rolls to much for my liking round corners.
( Also fitted rear anti roll bushes )
Now the problem I have is I dont want to replace these springs.
Can I just fit Rear Dampers, if so what ones.
Or can I get all round dampers that will synergize with the Pi springs?
eko
- Old timer
Arent Pi springs meant to be shite?
No offence mate but im sure ive heard they are crap?
toughguych
If you have ever wanted to modify a Touring then you may be in a possition to give constructive criticism.
Touring owners will know there is a limited choice of suspension upgrades available.
Thanks for the advise but it doesnt really help.
eko
- Old timer
Steady mate,bit touchy arent youtoughguych wrote:If you have ever wanted to modify a Touring then you may be in a possition to give constructive criticism.
I did say no offence intended
Limited choice for tourers?
Not from what ive seen?
toughguych
Youre not answering my orgininal request for advice mate.
Thanks for youre imput.
RAZ
The car looks the dogs mate but what took you so long? 87 -07???
suzie650
Well, actually he is answering it, as bad/unsuitable springs will affect the handeling. And before you ask, I do have a touring, and it was handeling poorly due to unsuitable springs. Put the right stuff and the roll is drastically reduced.
You'll see a nice choice of good springs on the Zone Shop to start with.
Best upgrade for dampers is bilstein b8, but what's the point in spending that sort of money on dampers without suited springs?
Seb
Seb
toughguych
Ya, Like 20 years!!
You must have been washing dishes for a long time to get the money together!
( No offence intended )
suzie650
toughguych wrote:Ya, Like 20 years!!
eko
- Old timer
5 months mate and its come a lot further than a set of Pi springstoughguych wrote:Ya, Like 20 years!!
toughguych
Suzie650, I dont really see any helpfull answers from eko only that he thinks Pi springs are "shite".
Thanks for your post.
When I was looking to lower my car without adding dampers Pi springs were one of the very few avalable for Tourings.
I used to own a 325 4 door and when I fitted eibach springs to it it responded alot better.
Not so for my Touring and Eibach dont make Touring springs so I was left with little choice.
The question I am asking is: how can I now stiffen up the car whilst keeping the Pi springs?
Or do you think I should start over?
Youre right, I dont want to throw loads of money at it.
That will do, children!
fuzzy
the springs will probably be fine if you uprate the shocks.if your running around on new springs and maybe old knackered shocks then it will wallow about like a boat in rough sea.i found there to be a wide range of suspension available for the touring when i was looking,just as much as the saloon.i eventually went with the bilsteins from the zone shop and they are firm enough to handle a thrashing but comfy enough for everyday cruising.the zone shop was also £50 cheaper per pair than my next lowest quote.spax adjustables with matching springs were to hard even on their softesr setting and seemed to cause top mount failures quite regularly
toughguych
I was waiting for someone to say that Brian! I am still working on the ecu/fuel pump issue.
Fuzzy, thanks,
Am I to assume that the Bilstein struts will accept my Pi springs on the front?
Or do I need to buy the whole lot? $$
Fuzzy, thanks,
suzie650
If your dampers are on their way, then as fuzzy said, replacing them might already solve your problem (I've heard of GSF bilstein (OEM, not the b8!), if you're on a budget).
If the dampers are already ok, I personally think it would be a waste of money to go for expensive ones with the current springs. So restart. H&R touring cupkit is apparently a very good solution, especially if you compare it to the price of the touring/cab specific springs. (never driven it myself, mind)
And if you only want to change springs, all the touring/cab' springs listed on the shop are known to be quite good. And I can vouch for the H&R.
suzie650
Bilstein are inserts, so yes... but it's not your best bet if tight budget. about £100 a corner...toughguych wrote:I was waiting for someone to say that Brian! I am still working on the ecu/fuel pump issue.
Fuzzy, thanks,
toughguych
Ya, just looked at the zone shop.
They look very good but yes, money is an issue.
£320 approx all round. ( - VAT )
Thats why I went with Pi to begin with, allas they are not enough.
To much for the old beast!
Laters...
Laters...
