Control Arm Bushes Nightmare
Omi
Witty custom rank.
Post Wed Feb 21, 2007 11:39 pm
Went and paid £70+ for M3 offset bushes from BMW today.
Eventually got the old ones off, ended up removing the control arms.
The genius I was working with decided to heat up the lollipops so the bushes would drift in easier... Did so, and drifted in the new bushes.
Workshop stinks of burning rubber and the outside of the rubber section of the bushes has just melted, resulting in the rubber section drifting in and out of the metal sleeve as we try and mount the ridiculously tight inners.
Eventually got em on, but the rubber is not fixed solid to the bushes anymore.
Are they fecked? Who will do it properly if they are and how much will they charge?
Supposed to be on Donington this weekend and I'm just a bit fecked off with the car this week.
...or is it?
cliffybabe
Powered by Nelly
Powered by Nelly
Post Wed Feb 21, 2007 11:46 pm
PM stuartgallafant he done mine for me
Omi
Witty custom rank.
Post Wed Feb 21, 2007 11:49 pm
Other end of the country... Going to take it for a ride tomorrow and see if the bushes move.
...or is it?
Chris-W
Post Thu Feb 22, 2007 8:33 am
I suggest they are ex-bushes.
I'll happily press a set in for you, but distance is, as ever, the problem.
Post Thu Feb 22, 2007 9:06 am
Ye Gods!! Some people shouldn't be allowed near a toolbox!!! Definitely ex bushes! Start again.
buster
Post Thu Feb 22, 2007 9:14 am
Dude !!!! i told you on the phone the other day dont use the oxycetelene !!!!
Post Thu Feb 22, 2007 9:19 am
They have to be pressed in using a hydraulic press or at the very least a vice that can withstand in excess of 2 tons! I wrecked my Record 1 ton vice only the other week trying to put mine in! Guy next door but one did them for me after the vice wrecking and he reckons it took 2 tons of pressure to get them in! One new vice later (an additional £90) and a bottle of wine for Dave the nieghbour and I'm a wiser man.
As above you bushes are ex buses! You live and learn by experience.
Post Thu Feb 22, 2007 10:20 am
Fire and rubber do not mix well 8O
buster
Post Thu Feb 22, 2007 10:26 am
use it to remove old bush,then hacksaw the steel coller.Oxy great for that !!!
But press new ones in :mad:
Ziggy
Post Thu Feb 22, 2007 10:31 am
:eek:
Tell the idiot to heat up his shoes in the same manner before he puts them on. Better yet, do it for him while he's wearing them.
chief
Post Thu Feb 22, 2007 11:14 am
would only dare suggest oxycetelene for removal, as 'DanThe' reccommends - fire and rubber not a great one for a lasting relationship
Don't you wish there were a knob on the TV to turn up the intelligence? There's one marked 'Brightness', but it doesn't work.
jaistanley
Post Thu Feb 22, 2007 1:46 pm
I fitted the polyeurathane 2 piece ones no probs with a vice, they need a lot less pressing than the BMW ones. First you insert the black ring, then the purple insert slips into that. For my new car I might fit the rubber ones (as it'll have lower profile tyres) for which I have a 6 tonne press now.
You could try lubricating them in with hairspray or a tiny drip of fairy liquid.
Didn;t I hear of a bmw lube/compound that allows you to fit the rubber interface bushes and that vulcanises the rubber and glues them into position??
Good luck, bummer about the bushes dude.
Jai
stuartgallafant
Post Thu Feb 22, 2007 9:04 pm
i think someone owes you a set of bushes mate!!!
handpaper
Post Thu Feb 22, 2007 11:55 pm
File a chamfer onto the outside of the bush and it can be tapped into the lollipop with a lump hammer. Place the bush on a flat, strong surface, like the back plate of a vice, and knock the lollipop over it. It can be a PITA to line up right, but if you don't have access to a press it does work.
Lordschleife
Post Fri Feb 23, 2007 4:49 am
I pressed the m3 poly ones in using a trolly jack, couple of bits of wood, and the underneath of the car
Seemed to do the trick, dunno if you'd be able to do the rubber ones like that though
Cheers,
Robin
Demlotcrew
Post Fri Feb 23, 2007 9:58 am
:eek:
jaistanley
Post Fri Feb 23, 2007 12:22 pm
I pressed my rubber bushes OUT using a bottle jack and a student accomodation door way.
Dislodged a few bricks but what did they expect? I was a scummy petrol head student.... (with an S50 in the outside toilet!)
Jai
