E30 cruise
oze30
How much do they normally go for, and will it fit an m30 conversion??
£100 for a complete working kit
the only problem i can see is the mounting of it in the engine bay and connecting the throttle cable, the actuator mounts on the bracket which holds the airbox. This is if the M20 was still fitted though. You could still get it to mount there i expect but without seeing the M30 in there it's hard to know how to mount the throttle cable
someone else may know more
nickso
- Location: Go do that voodoo that you do so welllllllll!!
yeh ive got it on my m30.
the throttle hole on the m30 is round and the cruise cable fitting is square....i just filed the round hole to make a square one if that makes sense.
space for the cruise motor is personal preference i reckon and depends on what space you have. the one i removed wasnt on the airbox mounting like simon said....it was on its own bracket spot welded to the nearside inner wing....ive been told they arent even mentioned in any bmw catalogue which is odd. might be wrong as ive not checked.
i made a bracket and mounted mine upside down right behind the nearside headlight. the plastic cover around the headlights may get in the way of that on yours though.....mine is long gone.
thats really the only problems i had on mine although getting any wires throught the bulkhead below the servo isnt much fun but im sure you know that
'88 e30 328i M52 track bint.
ian332isport
Early E30's had it mounted like that. Later cars had it on the airbox mount.nickso wrote:the one i removed wasnt on the airbox mounting like simon said....it was on its own bracket spot welded to the nearside inner wing....ive been told they arent even mentioned in any bmw catalogue which is odd. might be wrong as ive not checked.
Ian.
nickso
ahh i did think that might be the case. mine was a 323i right enough.ian332isport wrote:Early E30's had it mounted like that. Later cars had it on the airbox mount.nickso wrote:the one i removed wasnt on the airbox mounting like simon said....it was on its own bracket spot welded to the nearside inner wing....ive been told they arent even mentioned in any bmw catalogue which is odd. might be wrong as ive not checked.
Ian.
dimebag_from_hell
I really dont see the point in cruise control, my dad has it in his aston martin, he says its just a pain in the ass.
cliffybabe
- Powered by Nelly
i think cruz control is wicked, i use it loads on my mercdimebag_from_hell wrote:I really dont see the point in cruise control, my dad has it in his aston martin, he says its just a pain in the ass.
nickso
i use it all the time on the e30
saves fuel, good for motroway cruising, good for round town as well if you use it right.
it's excellent, makes driving alot more relaxing when the mood suits and saves you money it's a win,win retro fit
toby
Ali aka dark_sounds had a cruise control for sale. A few peeps on the thread said they wanted but don't know if he sold it. He was after £100
http://www.e30zone.net/modules.php?name ... se+control
Rosc0PColtrane
our roadsa re too busy for cruise control!!
shut up!blatantarrogance wrote:our roadsa re too busy for cruise control!!
oze30
Just have to travel at the right times!
nickso
if you know how to use it thats rubbish.......thats what the resume button is forblatantarrogance wrote:our roadsa re too busy for cruise control!!
