Headlights having a flid.... HELP!
RapidE30
Post Wed Feb 21, 2007 9:20 pm
Having a mare with my dipped headlights (face lift), there's power to the bulbs but they're not working.
Before you say the bulbs are duff, I've tested them out of the car and they work. I took the drivers side out to try in the passenger side, changed my mind, put it back in and now it doesn't work. :x
Crap, piss and bollox! :eek:
Help me Obi-wan-Kenobi!!!! :cry:
The 100% American is 99% idiot.
eko
Old timer
Post Wed Feb 21, 2007 9:22 pm
Theres an earth point behind the lights,passenger side i think?
Worth a look maybe?
Post Wed Feb 21, 2007 9:55 pm
Unscrew the black cover to the bulbs and check the voltage, with respect to the car body or engine, on both the centre pin of the bulb, and it's metal base flange. If they are both zero, then power isn't getting there.
If they are both 12 volts, then it's an earth problem as eko says, or if there's 12V on the centre and zero on the flange, the bulb is blown.
Greeny
Post Wed Feb 21, 2007 11:36 pm
I had exactly the same problem at the weekend with one of my front fog lamps, took the bulb out and put it directly on the battery and it worked but wouldn't work when in the lamp.
I checked there was power both sides of the 2 pin plug and it was fine. Couldn't work out what was going on so I tried a new bulb and it worked fine and is still working.
I think it must have been a bad connection inside the bulb.
Gone but not forgotten.
('92 325i Cabriolet)
mick_318is
Post Thu Feb 22, 2007 8:42 am
I had the same sort of trouble on the weekend as well. I was replacing one of my lights. When I had finished it wasn't working, then I swapped sides and both weren't working :-x
I ended up pulling the relay from the fuse panel, then replacing it. Tried it again and both lights worked????? 8O 8O 8O.
One thing I had though was a very weak battery so this might have had something to do with it.
Mick
RapidE30
Post Thu Feb 22, 2007 10:21 am
Greeny wrote:I had exactly the same problem at the weekend with one of my front fog lamps, took the bulb out and put it directly on the battery and it worked but wouldn't work when in the lamp.
Also finding my fogs have a mind of their own, just a gentle tap on the side of the unit brings them back on. :?
Will try some new bulbs after I've checked the earth and relay to see if that sorts it. :wink:
