sunroof scrapes?
dazleeds
old skool raver
old skool raver
Post Wed Feb 21, 2007 5:09 pm
have seen this on a few e30 so i know its not just mine
passenger side rear of sr panel has scrape marks on it as if it catches on something when the roof is open
any idea what causes this??
cheers
Daz
www.oldskoolfantasy.co.uk
maxfield
Post Wed Feb 21, 2007 5:13 pm
I has happened on my dads :cry:
Did happen before aswell
Must be something inside?
dazleeds
old skool raver
old skool raver
Post Wed Feb 21, 2007 5:27 pm
seen it soooo many times
surely someone has got round to sorting it and has the answer
bmwe30mtech
Post Wed Feb 21, 2007 5:31 pm
Daz, just lower the rear of the panel a few mm's. Im guessing you know you can adjust the height by loosening the torx bolts. May work.
316eyes
Post Wed Feb 21, 2007 9:26 pm
Isn't there an article on the yank site for adjusting the sunroof panel, to the exact spec.?
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
dazleeds
old skool raver
old skool raver
Post Wed Feb 21, 2007 9:30 pm
bmwe30mtech wrote:Daz, just lower the rear of the panel a few mm's. Im guessing you know you can adjust the height by loosening the torx bolts. May work.
tbh the panel looks spot on flat
and the amount of scraping there is i dnt think it would solve
think i need rooflining out and have a proper butchers at it
its gonna have to come out to do sunroof drain so guess i'll have to leave it till then
maxfield
Post Wed Feb 21, 2007 9:31 pm
Tell me your findings please :D
