Is there an idiots guide to fault finding or can anyone give me a few basic checks to do?
Cruise Control
boomer
Mine has just stopped working
nickso
- Location: Go do that voodoo that you do so welllllllll!!
does it do anything at all?
'88 e30 328i M52 track bint.
boomer
Nope - won't switch on, it was working fine yesterday
oze30
Fuses?? If they're ok, did you move anything under the steering column? Might pay to take the shroud off and have a quick squiz.
Also.. ot could you take a pic of it all please? I might be acquiring one and need to see how it fits.
cass1_5503
sorry to hijack but oze i have all the pics you should need as i was given them when i retro fitted cruise into mine if you pm me your email ill send them to you
boomer
Fuses are fine - it has started working again - must be a loose connection - I'll have a mooch over it at the weekend
Thanks peeps
Thanks peeps
Simon
Did you fit the system yourself?
If so, check the clutch switch, any movement can cause the cruise not to work.
