I'm turning alloy spacer rings to sit atop the strut top mount to raise the front by 35mm for night rallying but I can't have the car sat legless on the drive while I make them up. I intend to knock the 3 studs out and bolt the top mount to the ring then bolt down into the new spacer ring through the stud holes in the turret top. I know it'll screw the bump steer but frankly that's the least of the cars problems
1. What is the OD of the bit that butts up against the bottom of the turret (~5 inch so you know which bit I mean, it's the bit with the 3 studs in).
2. What is the OD of the bit that locates into the hole in the turret (~2.5 inch).
3. If I knock the 3 studs out of the top mount, could I replace them with 20/25mm M8 HT bolts, ie is there room to insert the bolts from underneath the bit that butts up against the shell?
4. A 35mm ride height increase (all from suspension) shouldn't take the bottom ball joints beyond their deflection limits should it?
Cheers,
jk
