Is my engine on its way out?
salami
Post Wed Feb 21, 2007 1:15 pm
Did an oil change at the weekend and gone to check the oil after a small run around the village and there is a very (very very)small amount of cream cheese on the dip stick and cap,could it just be condensation or is it f**ked,it has a very small coolant leak also but i think that is from a new water pump with a old hose. :cry:
snoops
Major Helmet
Post Wed Feb 21, 2007 1:17 pm
the heads probably on its way out
cliffybabe
Powered by Nelly
Powered by Nelly
it could just be a bit of condensation, Clean it off and take it from there give it a proper run and see what she is like
iDreamBeemer
Post Wed Feb 21, 2007 2:34 pm
That said, if you see it again after giving it a good run, the last thing you want to is keep driving it as you will screw up your engine. I did this on anther car, unknowingly, and managed to warp the pistons and truly buggered the engine up.
Ziggy
Post Wed Feb 21, 2007 2:44 pm
What was the old oil like & what engine is it? If you're loosing coolant & picking up mayo, I wouldn't hold out much hope for a crack-free head... You might be lucky though - 'tis the season for condensation afterall! :?
salami
Post Wed Feb 21, 2007 7:36 pm
Took it for a very good run and all is well must have been condensation bit of a ring twitcher though,a pipe was clipped wrong so thats the water done...filled up with fuel and tank is leaking from the very top,so spent the last 1 1/2 hrs driving round trying to use some fuel up :x
Ziggy
Post Thu Feb 22, 2007 9:54 am
Sounds promising! :) Keep a close eye on it though...
FlappySocks
Post Thu Feb 22, 2007 10:09 am
I used to have a 4.0L Jaguar. I once found moyo all over the cap and dipstick. It was really thick and creamy... It was so bad, I just assumed the worst, and expected to find the coolant to be contaminated too, but it wasn't. A good long run later, and it was all gone. Phew.
