How low to go and who's kit to use?
RapidE30
Post Tue Feb 20, 2007 9:20 pm
As above... the Tourer needs dropping a bit, not so much that it shatters my teeth but so it looks good.
Which kit would you recommend? Koni, Spax, G-max, ANother? :?
Any help appreciated as always. :D
The 100% American is 99% idiot.
fuzzy
He who sleeps with "Gingers"
Post Tue Feb 20, 2007 9:38 pm
so many different choices here. this is mine on a 60/40 drop which just about manages speedbumps without any dramas. i use bilstein shocks and that gives my touring a firm but not uncomfortable ride. you do get -80 kits but i dont think theyed be much good for everyday use. coilovers would allow you to set it to whatever height you fancy but are around £600+.
snoops
Major Helmet
Post Tue Feb 20, 2007 10:04 pm
go witht the 60/40 best looks as its balanced out and practical
RapidE30
Post Tue Feb 20, 2007 10:07 pm
snoops wrote:go witht the 60/40 best looks as its balanced out and practical
Do have to buy the 60/40 split separately or can you buy it off the shelf, if so, who from?
Is that 60 front, 40 rear? :?
handpaper
Post Wed Feb 21, 2007 1:26 am
60/40 kits are quite common 'off the shelf', and yes, that's 60 front 40 rear.
The zone shop sells them, among others.
riklusby
Post Wed Feb 21, 2007 12:41 pm
I went for a 70/30 kit which i sourced in Germany, fairly cheap, i found it a bit soft in the rear and it scrapes the speedbumps (hence the stainless corners under my frontspoiler) am saving for coilovers and poly bushes now.
However on previous E30s i always found Koni shocks and H&R springs to be pleasing and not too expensive !
cliffybabe
Powered by Nelly
Powered by Nelly
Post Wed Feb 21, 2007 4:09 pm
iv'e got 40mm all round with mtec shocks with Jamex springs
They only been on there a month but i have been tols it will sit lower once bedded in winkeye
scotty86d
Post Wed Feb 21, 2007 11:41 pm
bling bling rims there cliffybabe,is it sitting lower at the front now than in ur sig?
cliffybabe
Powered by Nelly
Powered by Nelly
Post Wed Feb 21, 2007 11:53 pm
scotty86d wrote:bling bling rims there cliffybabe,is it sitting lower at the front now than in ur sig?
Yeah mate, its now got the 40mm springs and mtec fronts on, in the sig it was before she was lowered, ive been told she will drop more over time once th ehsocks and springs bed in 8)
Im well pleased with the rims, cheers dude
munky30
100% Pure Council
Post Thu Feb 22, 2007 12:47 am
100/80mm. www.coilsprings.co.uk
Man up and drop your car properly instead of this 60/40 pansy sh*t.
(no offence, LOL)
jaistanley
Post Thu Feb 22, 2007 4:28 pm
Flipping heck..
Go for the H&R sport springs, -35 all round. Think you have to get the cabriolet ones for the touring.
Also get inverted Bilstein sprint (old name, check part nos) shocks.
Nice kit and not chavvy low. It might go round corners in the wet.
Jai
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Feb 22, 2007 4:41 pm
jaistanley wrote: Nice kit and not chavvy low.
:lol:
kam325itouring
Post Thu Feb 22, 2007 4:47 pm
i got h&r 35mm very impressed its for a tourer!
RapidE30
Post Thu Feb 22, 2007 4:53 pm
kam325itouring wrote:i got h&r 35mm very impressed its for a tourer!
I had a look at the old girl from a distance today, and the back end is so much higher than the front. The front wheels look snug in the arches, but there's still a gap of about 2" between the rear wheels and the arch.
It's a dragster in disguise! :cry:
kam325itouring
Post Fri Feb 23, 2007 9:26 am
2"!!! what std?? the rear is high on what springs? i had that on my tourer when i had the h&rs fitted but the front settles in alot quicker because of the wieght, the rear takes longer.
