Blower and Clock problem - Newby needs help
l16ydl
Post Wed Feb 07, 2007 11:13 pm
I've just bought a 316i auto for next to nothing, but like always, i got problems! I know there has been loads of posts for this but i simple dont know what i am looking at.
Firstly, my blower is not working at all. Tried the wire on the K7 relay between 30 and 87, still no joy. Is it the resistor? If it is how can i change it and is it easy? Any help would be grateful.
Secondly, my rev counter and economy dials are not working properly, is it the SI batteries? If so, where can i get some from? Also, the bulbs have gone in the clocks, how hard are they to replace?
If any one can get some tips and possibly some pics, i would appreciate loads.
Lloyd
Post Thu Feb 08, 2007 12:47 am
Fan is not the resistor pack, as it would work in the full speed position with a dud resistor pack. Fan motors tend to seize up with age if their bearings aren't lubricated every 15 years or so.
Access to the motor is through the removable section of the engine bulkhead under the bonnet.
Rev counter and eco gauge are quite possibly SI board batteries, if they are the old NiCd type and not the later Lithium type. First thing to check, anyway.
Bulbs on the clocks are dead easy to change once you've removed the clocks from the car - which you'll have to do to check the SI batteries.
While it's out and open, tighten the two small brass nuts on the back and solder the joints for the "220 ohm resistor". (Use forum search for details).
I get SI board batteries from CPC, but there are other suppliers.
l16ydl
Post Thu Feb 08, 2007 1:03 am
Ok, any ideas where i can get a cheap replacement and how hard is it to replace? Any pics?
Post Thu Feb 08, 2007 9:18 am
l16ydl wrote:Ok, any ideas where i can get a cheap replacement and how hard is it to replace? Any pics?
Fan motor?
Get a replacement from a scrapper - check it turns freely, and work some light oil into the bearings before you fit it.
Motor is easily accessable behind the bulkhead panel, and fairly easy to change, although the clips on the fan covers can cause a few expletives to be uttered.
l16ydl
Post Mon Feb 12, 2007 7:55 pm
Really stupid question but what kind of batteries should i get? :o:
jcjdavis1
Post Mon Feb 12, 2007 8:27 pm
Hi try this link to help get clocks out.
http://www.mark-e-roberts.co.uk/220%20o ... cedure.doc
Post Mon Feb 12, 2007 11:29 pm
l16ydl wrote:Really stupid question but what kind of batteries should i get? :o:
Open the cluster and measure the voltage across the batteries. Putting the SI board in the fridge for an hour will help show up dud ones.
There are two different types of board used, which use different batteries.
If they are 3 volt lithium batteries, then there is unlikely to be anything wrong with them.
If they are AA sized 1.2 volt NiCd batteries, then there is a good chance they are failing. If either of them has less than 1.2 volts across them then they need to be changed. If left they first go short circuit and drag down the supply voltage to other instruments, then they leak and bu**er up the whole board
It's difficult to find replacement batteries with exactly the same type of tags, so I use 2/3 AA size NiMH batteries from www.cpc.co.uk and fit them in with short wires from the PCB tag holes to the battery tags.
l16ydl
Post Mon Feb 19, 2007 10:07 pm
OK, not as bad as i thought, only took me half hour to get the blower out, thought it was going to take me ages!! Manage to pick the whole heater system for peanuts. Resistor was abit of annoying b*tch but finally got a full working heater.
Next, the clocks..... oh yey!!
Hath
Post Mon Feb 19, 2007 10:38 pm
not beign funny..? and im prbably wrong but if it was anyhting like my 316i auto..
my tachos stopped wroking today.. and it was because i blew a 7.5amp fuse u tryed checking that?
Post Mon Feb 19, 2007 10:58 pm
Hath wrote:my tachos stopped wroking today.. and it was because i blew a 7.5amp fuse u tryed checking that?
OP said it wasn't working properly. I took this as meaning it isn't dead, but if it is, then there could be a blown fuse, but other things won't be working as well.
10 and 21 are the fuses for the tacho. If 10 is blown you won't have reversing lights ( which are probably the cause of the blown fuse ), and if 21 is blown, you won't have interior lights or clock.
Hath
Post Mon Feb 19, 2007 11:08 pm
oh iw asnt having a go mate.. i was mearly pointin to another problem it possibly might be.. im a newb.. dont wanna step on anyones feet.
Post Mon Feb 19, 2007 11:15 pm
Hath wrote:oh iw asnt having a go mate.. i was mearly pointin to another problem it possibly might be.. im a newb.. dont wanna step on anyones feet.
No problem - you might be right.
l16ydl
Post Tue Feb 20, 2007 1:54 am
No, fuses are all working but i definately think its the SI batteries because when i start up in the cold they work fine for about a minute and then dont responed. The temp gauge sticks, the MPG doesnt work and the rev counter wobbles like Mr Blobby. Am i right in thinking?
Also, what speakers are in the front? I only got one speaker working in the whole car!! Need to have a look at the back of the stereo me thinks. :?
Reminds me, cl not working neither, have to look at that, any common faults? There is also the alarm which someone has cut the main wires to, could that effect it and is it worth repairing?
Post Tue Feb 20, 2007 9:41 am
Central locking - do a forum search for "red AND black" and my username, then look at the older posts, (before I got tired of repeating it).
A brass nut to tighten up on the back of the cluster might improve the temp gauge, but it definitely sounds like it needs a SI board or batteries.
Badly fitted alarms (and ICE) are always bad news. Just a matter of trying to repair the damage with a soldering iron and heat shrink sleeving.
Royalratch
Post Tue Feb 20, 2007 6:56 pm
Brianmoooore wrote:Badly fitted alarms (and ICE) are always bad news. Just a matter of trying to repair the damage with a soldering iron and heat shrink sleeving.
My immobilizer has stuck on. I took the wiring apart and it hjad fell apart because it was bullet plugged together with no heat shrink. The maufacturer states it must be soldered to be under warranty - it was installed by an approved dealer.
Anwyay, best/safest way to activate heat shrink without a heat gun?
Post Tue Feb 20, 2007 7:25 pm
Royalratch wrote:Anwyay, best/safest way to activate heat shrink without a heat gun?
In an emergency, I've used heat from a soldering iron held close to the sleeving, and the flame from a lighter wafted about. Never tried a domestic hairdryer.
jkarran
Post Tue Feb 20, 2007 7:28 pm
My imobiliser gave me hell so I cut it all out and soldered up the damage, was a similarlly rough sounding bullet connector and clip on splices job :x wouldn't have been happy had I paid for that!
My dials and fan were intermittent as well, I had loose/corroded connections in the loom under the dash (+ some other problems that I doubt were related) disconnecting/reconnecting them a few times seems to have solved the problems for now touch wood.
Good luck
jk
E30 320i Rally Turd - Usually broken
E24 635Csi - Rotting in peace for now
E34 540i - Daily driver
Blown R1 Striker - In progress
jkarran
Post Tue Feb 20, 2007 7:29 pm
Brianmoooore wrote:Never tried a domestic hairdryer.
Doesn't work very well.
jk
Post Tue Feb 20, 2007 7:31 pm
jk
Surprised - Some of them are as powerful as my heat gun.
jkarran
Post Tue Feb 20, 2007 7:41 pm
Hmmm... maybe I just borrowed a shit one :?
jk
Royalratch
Post Tue Feb 20, 2007 7:49 pm
I have aportable blowtorch. You know the mini cansiter based ones with a screw on nozzle?
Is that overkill?
Post Tue Feb 20, 2007 7:57 pm
Will probably melt right through unless you are very careful and keep the flame moving.
Royalratch
Post Tue Feb 20, 2007 7:58 pm
Cool man. Got one of those flameless lighters as well hat just seems to balst a mini-jet of heat - will try that.
Cheersa ll.
Gortour
Post Tue Feb 20, 2007 8:04 pm
Portable blowtorch and a lighter? Definate overkill I reckon.
One of those portable gas soldering irons may be good, if you get a decent one, it will come with the attachments to use it as a heatgun, hot knife, paint stripper etc.
l16ydl
Post Fri Feb 23, 2007 1:41 am
Right,
finally getting there, clocks almost finished, now for a decent stereo and speakers and fully operational cl!!! :D
