Ok, im going to purchase a 3:91 LSD for my 325i. I have been told that the 'cooling fin' is broken and that this will make no difference to the diff whatsoever. Can anyone confirm this for me please.
Secondly will a 1987 325 sport' bottom end go onto a 1988 325i head?
Thanks.
Diff and bottom end question...
Giggz
^stolen but not forgotten^
Ziggy
One cooling fin'll make naff all difference, but check there's no other damage. You could swap the cover over from your old diff if you wanted...
Yes, you can swap the bottom end over. Only difference is compression (higher on the old engine = better!) & management, but it's all interchangable easily enough
SPADGE
Giggz i still have the mint bottom end that head came from sat in my garage.
Yours for 50 quid if you collect it.
As for the fin it will not make any difference so don't worry about it.
Spadge..
Spadge..
Giggz
Thanks for the reassurance mate. Much appreciated. I will swap the cover over from my old diff then. Lovely!Ziggy wrote:One cooling fin'll make naff all difference, but check there's no other damage. You could swap the cover over from your old diff if you wanted...
Glad theres no issues with the bootom end too. But why is it better to have higher compression and how do mean that the management is all interchangable?
Giggz
Spadge thanks for the offer but im in the middle of a deal with Theo to take the one he has. He is alot closer than you too.SPADGE wrote:Giggz i still have the mint bottom end that head came from sat in my garage.
Spadge..
Thanks for the info mate.
