One of my smoked headlights has water in it
William
Location: Home:Suffolk, Uni: Cirencester, Gloucestershire
Post Tue Feb 20, 2007 2:37 pm
Any ideas how i can stop this from happening, the first pic shows the one with water in, the second the other side of the car without water in.
316eyes
Post Tue Feb 20, 2007 5:19 pm
Take it out, dry it on a radiator overnight and then check the seals for the main and sidelight buld are sound.
The only other place to check is the seal between the glass and the metal body, which is difficult to check.
I have seen someone fill a light with water to find a leak before now, and it worked!!
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
Post Tue Feb 20, 2007 6:19 pm
I know the Bosch dipped lamps have a vent at the bottom that can be removed, usually where the flies get in.
William
Post Fri Feb 23, 2007 5:16 pm
Ok, I filled the light with water and established roughly where the leak was coming from. Water pretty much pours out of the section circled, but I can't workout where the actual hole is or what it's for. Can anyone tell me what is behind there and why water might be able to get out of (and therefore into) it? Thanks
Post Fri Feb 23, 2007 5:27 pm
That looks like a Bosch projector to me, if it is then I would say that is your problem
William
Post Fri Feb 23, 2007 6:14 pm
it is a Bosch projector, but I took the projector off and the leak is in the other half.
William
Post Fri Feb 23, 2007 6:15 pm
and the other side of the car is the same and has never been a problem
suzie650
Post Fri Feb 23, 2007 10:31 pm
DanThe wrote:That looks like a Bosch projector to me, if it is then I would say that is your problem
What's the problem with bosch ones?
William
Post Fri Feb 23, 2007 10:57 pm
mating a bosch projector to a hella lense can be troublesome without sealant. mine are sealed and havent caused a problem, its just this leak which is coming from somewhere else
