Apologies if this is in the wrong section mods.
Has anyone converted later headlight to fit an early car?
From what i can make out all i need to do is to change the wiring connectors to the later type, 6 connectors instead of 4 for the early/pre face lift.
I was thinking of re wiring the later connectors by soldering and then shrink wrapping where the 2 wires connect, will this be ok for continuity?
Any input would be appreciated.
Oz
Later headlights on early cars?
oguz327
- Captain Armco
eko
- Old timer
Ive done exactly what you describe on my car!
Simple enougth to do and work fine
Cant remember the wire colours though but it will be obvious when your doing it!
Ziggy
Yes - p1ss easy, & really obvious what you need to do with the wires! Only essential thing is to smoke em first...
eko
- Old timer
AgreedZiggy wrote: Only essential thing is to smoke em first...
oguz327
- Captain Armco
Cheers fella, just wanted to double check before i start butchering
Ziggy, smoke in um up first for sure
Did you find the side lights had 2 black wires though, does it matter which way around these go?
Ziggy
Don't remember tbh, but it's just a light bulb... If they both go straight to the bulb then it doesn't matter, but if the nagative goes to the housing or something, you'll want to get it right (assuming there's some kind of negative earth going on...) Should be easy enough to see... I'll have a look tomorrow if you're still stuck though!
eko
- Old timer
I cant remember either
oguz327
- Captain Armco
Cheers Ziggy, may take you up on that if i get stuck, probably gonna tackle this at the weekend.
Many thanks for the help fellas
Ziggy
I'll take a pic or something tomorrow then anyway - always helps these things if you've got all the info to start with!
