Fitted them nine months ago
Slightly larger than standard
302mm diameter
by 28 mm (just enough to clear the steering arm)
Calipers are OEM BMW(1998 E38 728i) and are quite large
So 30mm hubc entric spacers were required
As the calipers wouldn't bolt directly to the struts,brackets had to be fabricated (from 15mm steel plate)
and had to clear the ABS sensor
Caliper needed a "little" modification to clear the original upper caliper mount
Not a lot of room left
