fuel tank - fuel pump problems :s
P_VIDDY
Post Mon Feb 19, 2007 9:53 am
my car has been making a weird whinin noise for the past week. after tracing the noise the petrol pump i looked under the car and the tank is dinted really bad.. not sure how this happened :?
how hard is it to replace the tank and pump on the drivers side?
Alyman
Post Mon Feb 19, 2007 11:49 am
The fuel pump is nice and easy - it's explained in the Tech Articles section.
I've never done it myself but I've heard that the tank can be a pain to swap over, think it depends on how rusty your car is undeneath!
charlE30
Post Mon Feb 19, 2007 4:26 pm
You need to remove the exhaust system and prop to get the tank out, not bad if all the bolts come undone.
Fuel pump is real easy and quick.
Good time to check/change the prop centre bearing and rubber guilbo (attaches to gearbox)
Charlie
BMW F31 335d xdrive
P_VIDDY
Post Mon Feb 19, 2007 4:37 pm
thanks for the help guys, i have now figured out how it has happened. some retard has jacked my car up by the tank. my car has been to a few garages lately and im not sure who has done it :x
charlE30
Post Mon Feb 19, 2007 4:41 pm
P_VIDDY wrote: some retard has jacked my car up by the tank.
:eek: sorry to hear that, it's bad when you can't even trust a garage to do a proper job. It's one reason why I'd rather take my time and do it myself, at least then I know it's been done properly.
Charlie
BMW F31 335d xdrive
BadDave
Post Mon Feb 19, 2007 9:35 pm
P_VIDDY wrote:how hard is it to replace the tank and pump on the drivers side?
Take a look here
http://www.e30zone.net/modules.php?name ... eltank.htm
Nicely written step by step guide in the Tech section
By yours truly
HTH
Post Mon Feb 19, 2007 10:33 pm
The place I get most of my E30s from carries them around on forklifts, so dented tanks are not unusual for me.
Take the fuel pump out and put a piece of 2 X 2 wood through the hole to the bottom of the tank. Apply lump hammer.
e30bmlover
Ac Schnitzer prophet
Post Tue Feb 20, 2007 7:16 am
Brianmoooore wrote:The place I get most of my E30s from carries them around on forklifts, so dented tanks are not unusual for me.
lmao... brian....you are a legend.
