Front Foglights
Fraz06
Post Mon Feb 19, 2007 12:19 pm
Hey Zone, I've got an 89 320i and the front fog lights ain't working, so got under the car and looked behind the foglights to see if the white connector going into the foglights was maybe loose, so i looked at the passenger side foglight and everything seems to be ok, no loose or broken wires and the white connector is in good order, so i moved over to the driver side foglight and one of the wires going into the white connector has broke off and is hanging loose, also the reverse lights don't come on when you put the car into reverse gear, Would the broken wire at the driver side foglight cause both front foglights not to work ? as well as the reverse lights not to work aswell ?
many thanks
kam325itouring
Post Mon Feb 19, 2007 1:02 pm
reverse lights more than likely the switch mine dont work either!!! i got the switch but gonna get it done when i get the clutch done.... my mates fogs didnt work when he bought his 325 i swapped the switch over with my car they worked, he bought a new switch from the dealers, hey presto!! front fogs.
