diff???
jaymoe30
Post Sun Feb 18, 2007 9:16 pm
just purchased a 325i sport replica, it started of as a 320i the last owner dropped a sport lump and g/box in. the 320 diff is still on it,i'm getting lots of noise,rev needle jumps into the red but not going that fast! i've been told i need a different ratio diff,anyone know what ratio i can use,and what else will need changing? thanx
snoops
Major Helmet
Post Sun Feb 18, 2007 10:28 pm
3.64 for economy or 3.91 - bit better acceleration,less economy which is what genuine sports have
Templ8e30
The 320i diff should be a 4.1:1, the late 325i sports used a 3.91:1 and the early sports used a 3.64:1, auto's usually have a 3.73:1.
Take your pick from any of the above, the 3.91 gives slightly better acceleration but less theoretical top speed, the 3.64 gives slightly less acceleration but higher theoretical top speed and the 3.73 is a compromise of the other two.
All 325i diffs are physically bigger than the 320i diff, they use the same mounting points and the driveshafts are the same. You'll need to loosen the clamp nut on the prop (behind the propshaft centre bearing) to shorten the prop by an inch or so to get it to fit. Obviously re-tighten it afterwards.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Conrad
Post Sun Feb 18, 2007 10:54 pm
What LSD is suitable for a 318is and how much can I expect to pay for one that doesn't require a rebuild, also how much would it cost to get a worn one rebuilt?
Templ8e30
Post Mon Feb 19, 2007 10:54 am
The E30 318iS uses a 4.10 small case diff same a the 320i, very rare to find one in LSD form.
The medium case 3.91 LSD from a facelift 325i sport or 325i touring (if it has the LSD version) will work fine.
Expect to pay about £250 for one in good condition or pay about £250 to have one recondition with new bearings etc. Your nearest gearbox reconditioner should be more than able to do this.
Cheers,
Iain T
jaymoe30
Post Mon Feb 19, 2007 6:13 pm
thanks a lot for that mate!, now iknow what i'm looking for ithink i'll try and get my hands on a 3:73, are they hard to find or will one pop up quite easy?
jaymoe30
Post Mon Feb 19, 2007 9:06 pm
i've just managed to speak to the guy who i bought my car from and he said a normal 325 differential was put on the car, so could it be the clutch?
SPADGE
Post Mon Feb 19, 2007 9:13 pm
jaymoe30 wrote:i've just managed to speak to the guy who i bought my car from and he said a normal 325 differential was put on the car, so could it be the clutch?
If the engine is revving and your speed not increasing then it most probably is a slipping clutch
jaymoe30
Post Mon Feb 19, 2007 11:16 pm
pal of mines got a 320i,and that things got loads more torque than mine,i just cant work it out?
jonb
Post Mon Feb 19, 2007 11:28 pm
Conrad wrote:What LSD is suitable for a 318is and how much can I expect to pay for one that doesn't require a rebuild, also how much would it cost to get a worn one rebuilt?
3.9 from a sport will do.
Will cost alot to get one rebuilt. And you wont pick one up for £50
